Amp in the cabrio
  • Mike 91 318ic
    • Jun 2004
    • 429
    Here's what I did and why...
    • Mystikal
      Wheel Fitment Expert
      • 9602
      Originally posted by chriskb3
      id mount amp and cross overs on the back wall of the trunk. the only problem i have with putting my amp in the trunk is that there is no circulation of air and the heat from the amp and exhaust build up quickly, expecially on summer days here in texas. a couple cooling fans (computer fans or whatever) blowing on your amp should help alot.
      If Cabrio trunks have the same ventilation passages as other E30 trunks, I don't see ventilation being a problem. If anything our trunks are way more ventilated than other cars.
      • Tze30_34
        • Oct 2004
        • 13
        Hey Mike, I read an earlier post by you, I heard about this weight in my trunk before. Where do I find this thing so I can ditch it? How is it fastened to the car? Thanks.
        • parkerbink
          • Jun 2004
          • 10137
          Originally posted by Mystikal
          [If Cabrio trunks have the same ventilation passages as other E30 trunks, I don't see ventilation being a problem. If anything our trunks are way more ventilated than other cars.
          I have had heat issues (in 100 degree heat running the amps for 12 hours at a time) which is why I moved mine inside under the seats.
          • NC325iC
            • Mar 2004
            • 6565
            the weight is wehre the battery would be in a non cab, its underneath the carpet and a metal plate, held in by some bolts
            its friggin heavy as hell
            • Mystikal
              • 9602
              And do other car trunks manage to work under those conditions?
              This is like complaining about tires that wear out after 12 hours of track driving. Kinda out of context, especially when the guy never mentioned anything about providng music for an all-day festival at the equator.
              • parkerbink
                • Jun 2004
                • 10137
                Did I say something offensive? I think not. I provided my experiene. Since I moved my amps I have had no problem.
                I have had amps in the trunk of many other cars and driven all day without issue so I think the BMW trunk is more air restrictive.
                Chill out, man.
                • chriskb3
                  • Jun 2004
                  • 153
                  i have found this to be true.
                  in addition to the smaller trunk space (less air volume), and a double steel wall (which keeps more heat in and cool out from the cabin), theres also no ski hole which when opened can allow a lot better air flow and cooling in the trunk.
                  • Mystikal
                    • 9602
                    Chill out, man.
                    Haha, reading this after work I sure came off like an asshole. Sweet.
                    My bad.
                    • parkerbink
                      • Jun 2004
                      • 10137
                      No worries here.
                      Have a great day!
                      • Mystikal
                        • 9602
                        Oh, I'm better now. I got the A/C converted today finally and picked up the car this afternoon; it's been 90+ for the past few days and is forcasted to continue like this for a while. :shock: That, plus the fact that I haven't even driven the car since spending all night Sunday installing my new Konis probably led to my Eurospeed-esque PMSing earlier. :P
                        • BENdashdash
                          Tom is not my friend
                          • Aug 2004
                          • 2506
                          Since we're way OT, I've got another cabrio question.
                          I've seen pics of e30 cabrio setups with the sub(s) firing upwards. How is this better than facing back? I'm thinking about building my box at an upwards angle. Does the angle really matter?
                          • chriskb3
                            • Jun 2004
                            • 153
                            the angle dosnt matter, atleast not in the trunk of a cabrio. i think the main reason for having subwoofers firing upwards is more of a space issue more than anything else. ive had 2 12 inch subwoofers firing upwards only because they would not fit if they were mounted in a box vertically.
                            • BENdashdash
                              • Aug 2004
                              • 2506
                              okay, thanks
                              • parkerbink
                                • Jun 2004
                                • 10137
                                Exactly why mine are firing up. er were, whole stereo is in the closet since the car is out of commission.
