Tweeter install in a non premium sound car.
  • tehwickerman
    • Dec 2008
    • 1088
    Can someone give me some advice on how this is done?
    I've done a lot of research and all the articles i've found thus far are not very helpful.
    I'm attempting to wire the tweeters in a 91' 318IS I have OE front component speakers and OE tweeters to match.
    If someone would do a writeup on this it would be very beneficial to a lot of people!
  • Simon S
    • Oct 2004
    • 3758
    There's not much one can write up about.
    Here's what I did with 2 part epoxy and Infinity tweets:
    Not too pretty - but you won't see it - and they aren't going anywhere..
    -----Zen and the Art of e30 Maintenance - / - Zen TOC - / - Zen Summary
    • bmwguy325is
      • May 2011
      • 1263
      All I had done is gut the OE tweet and glue in the new one. Its low tech but works.
      sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
      The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
      • Simon S
        • Oct 2004
        • 3758
        Even better.
        Small dab of super glue or something for OE tweets
        (how old are those anyway? lol)
        Needed to use epoxy for the aftermarket units..
        • bernzpeed
          • 3917
          there is a wire already waiting on the door for the tweeters to be installed.
          i just did this last week. i installed a OEM premium sound system in a non ps car.
          pry the tweeter delete off carefully and then you will see the wire/ terminals waiting for the tweeters.
          Then you in the kick panel, remove the speakers and look for the wire that corresponds to the same color as the tweeter wire. it is not connected to anything and there is a terminal attached to it.
          89 E30 S52
          Transaction Feedback.
          • bernzpeed
            • 3917
            Premium speaker + tweeter retrofit
            Tweeter wiring should look like this with the premium speakers.
            Sorry for the ugliness, that is from my donor car which I followed so I can get the tweeter working.
            89 E30 S52
            • bmwguy325is
              • May 2011
              • 1263
              Originally posted by Simon S
              Even better.
              Dont use super glue. You may want to upgrade one day. He ussed hot glue. It fills in the gaps quite well. And then if u want to change them it cuts right out.
              • StereoInstaller1
                GAS
                • 22679
                A good quality super glue is best/easiest. Hot glue inevitably melts, epoxy is a bitch to get off, but you can flex the glue points just a bit and super glue pops right out.
                Closing SOON!
                Thanks for 10 years of fun!
                • Simon S
                  • Oct 2004
                  • 3758
                  Aw jeez. Quite right. Was thinking the installation of tweets to tweet pods there at first..
                  As mentioned - factory provides 'door wiring' so it's an easy matter to plug in at just under the sail panel - and at the kick panel.
                  Jesus Christ bernz - lol
                  New tweeter pods w/ tweets are like $70+ each so the pods/panels alone are desirable. Many, (like myself) source old/used ones and swap in tweets from a fresh/new component set.
                  • bernzpeed
                    • 3917
                    Thanks to Luke for all the support in helping me with the wiring.
                    I bow down to your superior knowledge. :-D
                    89 E30 S52
                    • tehwickerman
                      • Dec 2008
                      • 1088
                      thanks guys, after looking at the wiring diagram for awhile i figured it out very easily. the OE speakers and tweeters sound great! my system sounds amazing for a 20 year old car.
                      • bmwman91
                        • Oct 2004
                        • 3134
                        Did you plug the tweeter wires into the stock connectors? If so, I think you are running the risk of blowing them out. The cars with factory installed "premium sound" had crossovers in there to protect the tweeters. You should see about crossing the tweeters over, unless you have some sort of component system crossover in there already (in which case, you are fine).
                        Transaction Feedback: LINK
                        • bmwstephen
                          • 2463
                          would this be a concern if you had an aftermarket HU?
                          • bernzpeed
                            • 3917
                            the BMW premium speakers already have the crossovers soldered on the back of the speakers. so it's fine to connect them to the original wiring harness. it's not affected by the HU. well, it does in terms of the awesomeness of the sound output.
                            89 E30 S52
                            • bmwstephen
                              • 2463
                              ahh thanks for chiming in christian. so with regard to the kick panel speakers. are they the same between regular and premium equipped systems?
