Has anybody tried the autoloc 4 window module? same price, 4 windows, should fit the bill. This one right meow.
That is the Scytek unit I use. It does 2 windows up and down, 4 windows up or 4 windows down.
The issue is that the trigger circuit runs both windows up at the same time, so you cannot use it for proper dual window "one touch". You could use it to roll up or down all windows, but not individually.
Closing SOON!
So Scytek makes that autoloc module? Interesting. Have you found anything that works to control both windows seperately? It just seems silly that you'd have to purchase a module per window.
I have yet to find a module that has separate controllers per window. Scytek does not make their 2 window module, just that one. Well, they may have changed, I have no clue. The old 2 window Autoloc module would do 1 touch just by installing it normally, I just want mine to run on the soft touch switches as BMW intended.
Closing SOON!
I'm surprised no one mentioned the DEI 530T yet. One module controls two windows separately. Pretty easy to wire up too. If you want to use it with E36 switches, you need switches with large white plugs.
I think the size is not too bad. I put mine in the dashboard behind the black plastic pieces in the glove box. The wires are long enough. But my car is RHD so that may make it different.
And price-wise I think they're comparable. At least on Amazon the DEI is cheaper than two Autoloc. But you may be able to find a better deal.
What else do you guys find the DEI lacking? I've used it for several years in my previous car and didn't find anything wrong about it. But maybe that's just me because I didn't look for a lot of features. Not trying to defend the DEI but I wanted to mention it as another possibility after I saw Luke's comment for not able to find a module that controls both windows separately.
