Very Cheap 5.25 3 way speakers, that sound great!!!
  • 5Toes
    • 9836
    Im running these, or atleast something REALLY similar. Spending all my money on proper sub, amp and deck.
    And.. I plan on doing proper door pods later
    • dogsbark26
      • Nov 2008
      • 533
      My car did not have the premium sound so did not come with factory tweeter sails. I did buy used tweeter sails that I'd like to hook up before trying to replace the tweeters in them with new ones but I haven't decided on what ones to buy yet.
      • airkhin
        • 593
        f* it, just ordered a set, im sure will sound better than the one blown i got now... 23$ isnt too horrible... haha. im just curious how to run the factory tweeter with the speakers, since i ran all my own wires from deck to speakers...
        • StereoInstaller1
          GAS
          • 22679
          If you want to use the stock tweeters, you need to use passive crossovers.
          You can make your own with about $10 worth of parts or just buy a set on ebay or whatever.
          Closing SOON!
          Thanks for 10 years of fun!
          • CrusherCurtis
            • 2532
            passive crossovers.
            Passive Crossovers???????? Please go on......
            • StereoInstaller1
              GAS
              • 22679
              go on what? All speakers need a crossover of some sort (audiophiles, shut up, lets not go too far here) as obviously a tweeter can not safely get a full-range signal. You need to get all of the midrange out, obviously the bass too.
              What I am talking about is a very simple passive crossover, like every set of component speaker come with. Better crossovers sound WAY better...that weird crap on the back of your stock premium sound speaker is what the E30 uses.
              Does that help at all?
              Closing SOON!
              • CrusherCurtis
                • 2532
                What's your opinion on stereo's that have High pass filters? Are they enough? Are crossovers better?
                • StereoInstaller1
                  GAS
                  • 22679
                  A stereo with a high pass filter will be roughly 120Hz, tweeters need to see a minimum of roughly 4Khz, not even remotely close.
                  Passive crossovers are a necessity on an install like yours.
                  Closing SOON!
                  • reelizmpro
                    • 9534
                    The stereo built in cross over is okay for mid range speakers but from there the separate tweeters should have it's signal passed through a high pass filter. A passive filter is straight forward and cheap. You can build your own and tailor the cutoff by choosing the capacitance of the capacitor you use.
                    88 M3 - LACHSSILBER
                    89 M3 - ALPINEWEISS II
                    • CrusherCurtis
                      • 2532
                      My stereo is set to 160hz and think it sounds pretty good. To my ears it sounds like the tweeter only play high sounds. Where do you even mount passive crossovers in an e30? Is there any room behind the tweeter sails?
                      • StereoInstaller1
                        GAS
                        • 22679
                        No, you would mount them in the dashboard after you extended the wires.
                        I really think you should head down to a local car stereo shop and spend a bit of time listening to "good" shit. Bring your own music so you are familiar with what you are listening to.
                        If you are crossing your speakers at 160Hz, you car has ZERO midbass...the E30 already suffers from lack of midbass and you filtered the last little bit out.
                        Your tweeters, if still working, are playing information they are simply not capable of playing for any length of time or with any clarity.
                        I am not trying to be a dick here, but I have been a professional high-end installer since 1980. If I, or any other serious professional offer any advice, you really should consider it. There are LOTS of differing opinions, but what you have there is just completely wrong. A few bucks, a little knowledge and a little effort is all it takes.
                        Luke
                        Closing SOON!
                        • Vtec?lol
                          • Dec 2009
                          • 3278
                          My man luke is too right!
                          I've used Polks "MM" series in front and used the factory capacitor off the back of the stock premium speaker and even it wasn't up to the task.
                          Bottom line, there's no way your system sounds good with factory tweeters and 70-120hz being cut out of your mids. Don't let the subs do the work of your midrange, that's begging for distortion. It may be better than stock but once you spend the little time and money it takes to properly tune your system, it's worlds different
                          • 5Toes
                            • 9836
                            Besides tuning... Luke what do you say about these speakers?
                            Got any alternatives?
                            • 84driver
                              • Aug 2011
                              • 234
                              I'm looking at the Rockford Fosgate R152-S, very well-reviewed for the price on SonicElectronix and available on fleabay for $53 new.
                              I already have RF rears and sub, and I have had good experiences with RF in the past, so I think these will be a great match.
                              I also looked at the 5.25 MB Quarts, the FSB213 and the DSH213. They are the same price and MB Quarts are recommended by Luke, nothing else that cheap or cheaper is as well reviewed...
                              PAUSE
                              Ok, looking closer it seems that the discontinued (but still available) DSH213 has the nicest specs of the bunch:
                              DSH213:
                              1" Titanium Tweeter
                              Nicer crossovers fixed at 3800Hz
                              Rubber woofer surround
                              FSB213:
                              3/4" Titanium Tweeter
                              Inline crossovers fixed at ???? No information anywhere!!!
                              Butyl rubber woofer surround
                              R152-S:
                              1/2" Mylar Tweeter
                              Tiny crossovers in the tweeter fixed at 12Khz :(
                              Foam woofer surround
                              It looks like MB Quart used to sell nicer crossovers in models like the FSA213 and the DSE213 but their new 'Formula' FSXXXX line they went cheap. I'm now worried the RF tweeters are junk... I don't expect that the mids really hit cleanly up to 12Khz either. Pretty sure I just sold myself the DSH213s. Get 'em before they disappear!
                              balticblau-metallic '84 318i 5spd 3.91 LSD
