How do I disconnect the beeping when the drivers door is open?!
  • miichaelsmith
    • Aug 2011
    • 300
    I may just kill myself..it's doing it while the door is closed and the keys aren't even in the ignition
  • AndrewBird
    The Mad Scientist
    • 11898
    The door gong is mounted to the knee panel under the steering wheel. There should be a little plastic access cover you can pop out that it is clipped to. Unplug it and huck it down the street.
    Problem solved.
    • miichaelsmith
      • Aug 2011
      • 300
      I can't find it...
      • reelizmpro
        • 9552
        It's a little speaker box under the steering column. It might not be in it's original location but hanging around somewhere. Just unplug it.
        On a side note, I may just put mine back in. I think it gives that originality back to the car since many people delete them. I also miss setting the top speed limiter and having it gong whenever you hit it. Always thought that was a cool feature.
        88 M3 - LACHSSILBER
        89 M3 - ALPINEWEISS II
        • AndrewBird
          The Mad Scientist
          • 11898
          Does your car have an airbag?
          See the little plastic panel in the upper left corner? That is where the gong is. That is a non airbag panel though, so if you have an airbag, it will be different. Not exactly sure if the gong is mounted in the same place on an airbag car.
          • reelizmpro
            • 9552
            You got it backwards. That is the 2nd half of the airbag panel. The early style is all 1 piece.
            88 M3 - LACHSSILBER
            • miichaelsmith
              • Aug 2011
              • 300
              I found it guys thanks!
              • AndrewBird
                The Mad Scientist
                • 11898
                DOH! You are totally right. My bad.
                • AndrewBird
                  The Mad Scientist
                  • 11898
                  For future reference, this is the NON-airbag panel:
                  • dkbmxer002
                    • Nov 2007
                    • 1389
                    e30's beep when the door is open??? mine hasn't been in since i bought it years ago hahahaahh
                    • reelizmpro
                      • 9552
                      yes. its a "gong" that gets on your nerves after a while.
                      88 M3 - LACHSSILBER
                      • Quadrajet
                        • Jul 2008
                        • 1278
                        Does the Gong sound when the headlights are left on and the key is out? If so I may reconnect mine as well, always seem to drive thru fog to get somewhere, then it's clear at the destination.
                        • reelizmpro
                          • 9552
                          No, it only works when the door is open, top speed limit is reached or when the temp dips down to...30 degrees? or something like that.
                          88 M3 - LACHSSILBER
