turn signal problem! help please!
  • mkcman17
    • Jul 2010
    • 8240
    flasher relay makes a buzzing! i've changed with two working relays, as well as another working signal stalk....still doesn't work...
    1989 LN106 Hilux / 3.0TD SFA
    1974 2002tii / stock
    2002 IS300 / 5spd LSD
  • AndrewBird
    The Mad Scientist
    • 11898
    There is likely a short somewhere causing a high load on the flasher and making it buzz (basically it is flashing at VERY high speed). I'd start by looking at the bulbs at each corner, cleaning the sockets and checking all the grounds. This type of stuff is usually caused by corroded sockets.
    • mkcman17
      • Jul 2010
      • 8240
      will do. happens both left and right directions; hazards also no dice.
      • Tamataz
        • Aug 2011
        • 319
        How do you suggest cleaning the sockets?
        Originally posted by Sagaris
        He wasn't around because he spent 7 years in jail for assault. There was a group of guys doing a 24v swap on someones car and one of the neighbor kids came over and starting too many questions. Tempers flared, sawzalls did work, and he cut the kids leg off. The victim later joined this forum under the name "5toes".
        • reelizmpro
          • 9520
          sand them, contact cleaner, etc. Try another hazard switch Mike. Easy enough to change out and it does affect other things as well.
          88 M3 - LACHSSILBER/SCHWARZE
          • ButtJuice
            • Dec 2009
            • 2609
            You fix this problem?
            1991 318is - Sold
            1986 325 - Sold
            Instagram - Lamoursum
            • mkcman17
              • Jul 2010
              • 8240
              i tried that, as well as the relay and signal stalk.
              i ended up selling the car with no signals :/
              then it was flipped on ebay.
