Battery light charging problems
  • foundation982
    • Apr 2011
    • 180
    Okay so I swapped a new cluster into my 325e and it worked for a couple months the other day while driving home from work it died on me, found out the culprit was the battery light in the cluster wasn't exciting the alternator, I swapped my old cluster in (odometer doesn't work) and the light lights up and charging is perfect.
    Yes I know the light could be burned out and swapped a good light bulb in and it still won't light up, is this a problem in the cluster? anyone else have experience with this problem? I want my odometer back!
  • reelizmpro
    • 9552
    Why not just fixed the odometer It used to be, that when the battery bulb went out the car would not charge. Then in late 85 IIRC, they used a resistor in parallel with the bulb so if the bulb went out the car would still charge. What year is your ETA?
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • foundation982
      • Apr 2011
      • 180
      My Eta is an 86' but the only thing about the one with the bad odometer is it's also an i cluster it came in my car don't know why and the RPMS don't seem accurate
