In the active check panel my brake warning light stays on. I've switched out a few bulbs and cleaned off any corrosion on them. There seems to be some corrosion on the 3rd brake light connector that I cant get off. However all the bulbs light up fine. its a vert so I have the weird 3rd brake light. What else? Bulbs are all nickel.
Its been on since i bought it. I heard you have to hit the brakes one time for it to go off. Is it possible the brake light switch is bad?
