condenser fan
  • dronbot
    • Jun 2011
    • 32
    condenser fan
    my condenser fan is not turning on when i turn on the A/C and i do not
    have and refrigerant in the system.
    now the question is does the condenser need to be under pressure for the fan
    to kick on??
    like i said no refrigerant in system so i know its not going to cool.
  • redsubdivisions
    • Feb 2011
    • 1762
    Check the resistor. Those generally take a shit.
    1989 325i - 2.7i, Holset H1C, 60lb injectors, whodwho MS-PNP.
    2012 Passat TDI - DD Duty
    2008 GMC Yukon XL Denali - Kiddie hauler/grocery getter
    • bimmerteck
      • 762
      No, the aux fan in independent of the pressure switches. Pin 2 and pin 3 of the radiator temp switch will activate both speeds of the fan assuming the low speed resistor is good, if you doubt your wiring/resistor jumper the high speed fan relay directly to test the fan's operation.
      • TobyB
        • 5293
        Actually, if there's no pressure in the system, turning the ac button on won't trip the
        low speed of the aux fan. There's a low pressure switch inline with the compressor and fan.
        Only overheat will.
        ETM, for the headache...
        t
