I have an 85 325e without premium sound I'm looking for a wire in the trunk that is only hot on accessory to run a small amp. I tried reading some wiring diagrams but until they make a rosetta stone to understand them till then I'm lost. As of right now I have the power hooked up to red antenna power wire and seeing if it kills my battery tonight.
Hot on accessory
You car is probably pre-wired for premium sound. Find the harness and probe any wires with the ignition on for 12volts. Then remove the key from ignition and check to see if they are switched.
Your small amp might blow antenna fuses for antenna circuit.
It would be smarter to wire your amp directly to the battery, then use a "remote turn on" wire from the head unit or factory amp harness, which is probably pre-wired in the drivers side of trunk behind panels.Owner - Bavarian Restoration
BMW and European Electronics Repair and Restoration
www.BavRest.com
My Feedback Thread
Our Facebook!
Follow our Instagram!
Will do thanks.You car is probably pre-wired for premium sound. Find the harness and probe any wires with the ignition on for 12volts. Then remove the key from ignition and check to see if they are switched.
It would be smarter to wire your amp directly to the battery, then use a "remote turn on" wire from the head unit or factory amp harness, which is probably pre-wired in the drivers side of trunk behind panels.Comment
