keyless entry, doors lock but don't unlock
  • idanity
    • Jun 2006
    • 775
    more specifically.
    when i arm the alarm, nothing happens with locks...they stay open.
    when i disarm the alarm, the locks will then lock.
    i have: wires on car, to wires on alarm
    green w/black stripe (connected to neg out lock)
    green w/purple stripe (connected to neg out unlock)
    brown
    white
    blue
    am i using the wrong wires ? (just going on some google searchs and haven't found a wire color schematic to locking in the e30 (yet).
    everything else seems to be working fine, just not the locks.
    they do work from the trunk + key turns.
    3 pedal club
    200,k+ club
    cabrio club
    port-matched- polished- purring www.BMWpark.org
    </div>
    linux since 1999
  • reelizmpro
    • 9558
    Sounds like you have them backwards.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • idanity
      • Jun 2006
      • 775
      yea..so i wired them in both directions...if i reverse the connections, nothing happens at all.
      the only way anything happens is when it locks the locks while disarming the alarm.
      what does the white, and blue wire function as ?
      3 pedal club
      200,k+ club
      cabrio club
      </div>
      linux since 1999
      • idanity
        • Jun 2006
        • 775
        got it.
        works without any relays, actually quite nice.
        fwiw, it was a bad ground.
        the e30 has 2 green wires from the kick panel to the trunk, down the drivers side.
        (actually, 2 green, brown, white, and blue)
        green with black stripe locks
        green with purple stripe unlocks.
        brown is ground
        white + blue are unused (i wonder if its for drivers side priority ? )
        3 pedal club
        200,k+ club
        cabrio club
        </div>
        linux since 1999
