service lights?
  • Wschnitz
    • 8089
    service lights?
    My gauge service lights. The green yellow and red, don't work. Idk if PO swapped it or what, is it worth fixing? Or is it just a pain to have the dealer reset?
    willschnitz
  • Jean
    • 18228
    if they don't work dealer won't be able to reset them....think McFly.
    • reelizmpro
      • 9558
      Lol. If some of them turn on (from right to left, skipping) with the key on then u have cracked solder joints. If none of them ever turn on, then chances are the board is missing.
      88 M3 - LACHSSILBER
      89 M3 - ALPINEWEISS II
      • flying_violin
        • Jan 2011
        • 325
        If you ever end up getting it working, you can reset it by jumping pins 7 and 19 (I believe) in the diagnostic connector and turning the car on, engine off. Waiting 3 seconds resets the oil light and waiting 10 seconds resets the inspection light. Then turn the car off, remove the jumper, and screw the cap back on the diagnostic connector.
        However, if they are already broken, you never have to reset them!
        Alpine II 318is
        • Wschnitz
          • 8089
          K, pulling cluster out doesn't sound easy.
          willschnitz
          • Gregs///M
            • Mar 2012
            • 2459
            Its not that. Remove the trim around the cluster and use a small flathead to pry each connector housing out. There is a black release retainer on each connector, that retainer must be lifted outward and the plug will come out. Once most or all of the connectors are out, feed the cluster out toward the center of the car, toward the passenger side.
            Should be able to come out without taking steering wheel out.
            I have replacement LED board if yours is missing or damaged. Pm me if you need one. I also have rebuilt SI boards if you need one of those, your SI batteries might be dead.
            Owner - Bavarian Restoration
            BMW and European Electronics Repair and Restoration
            www.BavRest.com
            My Feedback Thread
            Our Facebook!
            Follow our Instagram!
            • quikveedb2
              • Sep 2007
              • 2258
              Removing the steering wheel makes the job 100% easier, imo, and it's 1 bolt. Also put a rag over your steering column to prevent scratching the clear plastic covering the gauges.
              You know why you're drinking that Pabst? No its probably not because it was the first beer you grabbed. It's because you're a winner.
