i heard about an antenna delete with rear defroster. true? or false?
  • cikisdeadly1
    • May 2012
    • 164
    hey guys i heard that there is a way that i can hook up my rear defrosters on the window to work as my antenna. i would love to know how this could be done. i currently do not have and antenna and dont really want to pay for one. also it looks stuped when the antenna goes up. if you know how to do this let me know plz.:)
  • DRTSRFR
    • May 2008
    • 1836
    Interesting idea.
    ...looks like this guy was successful...
    http://forums.corvetteforum.com/c3-t...-it-works.html
    Suspension tips here...
    http://www.r3vlimited.com/board/album.php?albumid=757
    • cikisdeadly1
      • May 2012
      • 164
      sick. ill let you know if it works or not. not sure yet if i really want to do it but, its worth a try
      • reelizmpro
        • 9534
        That's how later cars get radio reception.
        88 M3 - LACHSSILBER
        89 M3 - ALPINEWEISS II
        • g.ruff561
          • 1266
          Check with Silence at Condor or John at Wot-Tech in South Fla. 954-867-8389.
          • g.ruff561
            • 1266
            The correct number is 954-867-8388
            • evandael
              • Oct 2009
              • 2881
              my mom's old passat w8 had an antenna integrated in the rear window. i imagine it was via the defroster.
              edit: check this link http://www.ek9.org/forum/resource-ar...r-antenna.html
              • StereoInstaller1
                GAS
                • 22679
                The issue is that there is only 1 grid, and of you were to try to connect it and the radio at the same time, you would likely smoke your deck.
                You could easily use a couple of relays and have them toggle when you used the defroster.
                Closing SOON!
                Thanks for 10 years of fun!
                • g.ruff561
                  • 1266
                  Would it be possible to disconnect the defrost and just use the grid for an antenna? I an in Florida. No need for defrost.
                  • StereoInstaller1
                    GAS
                    • 22679
                    absolutely. Should take an hour to do the whole damn install if that is how you plan it. In fact, you could do the whole job behind the radio.
                    Closing SOON!
                    • jrobie79
                      • Mar 2006
                      • 2526
                      luke can you offer insight on relays to toggle between the two functions? i'm up in MA and definitely will be needed the defrost, but I currently have no antenna. it sux when my phone dies and I forget to bring a couple CD's
                      1991 318i ---- 308K - retired
                      • g.ruff561
                        • 1266
                        And offer insight into " behind the radio" connections. A lot of us would love to delete our antenna. Just one less motor to fix or replace. Thank you sir.
                        • dwvw
                          • Sep 2011
                          • 234
                          I am super busy at work, but if I have time, maybe I will try it out using relays and make a post.
                          • g.ruff561
                            • 1266
                            The rear defrost grid should work perfectly. I have heard that most antenna's designed into the front or rear wind screen have only one wire that travels the perimeter of the glass. The E30 rear defrost has several wires. That may give a much better signal strength.
                            • AbsorbantNut
                              Non faccio funzionare questa merda
                              • Jun 2010
                              • 2491
                              Yeah, it's been done before. Check with Silence, he did it on his matte 318
                              '73 2002 m20 turbo [sold] '87 rat rod 325is [couch modded] '91 vert [daily] '88 325is [spec build v1] '84 325 [spec build v2] '99 323i vert [sold]
