I've got a few problems and I haven't had much luck trouble shooting so far. I have done plenty of searching and have not found my solution yet and I'm hoping for ideas of what to check next.
1. Cluster water temperature gauge not functioning.
It has not worked since I bought the car. It never budged (even a flicker) out of the 'off' position in the blue. The rest of the cluster worked fine. I have an aftermarket gauge in the ashtray location to make sure I am not overheating. I recently replaced my timing belt, water pump and thermostat. This did not solve the problem.
Ill take you through the steps I've taken.
First I removed the cluster and checked the ground nuts on the back of the gauge cluster. They were tight, but I went ahead and removed them, cleaned and re-installed. Reinstalled the cluster, didn't fix the the problem
Second, I checked the thermostat sensor/sender and connectors. The connector wires are not frayed and look fine. The connectors are holding tight, the plastic seams to be strong and the pins don't look eroded. So I replaced the sensor and sending unit with brand new ones from pelican parts just incase they had gone bad. Didn't fix the problem
Third, I replaced the cluster and double checked the ground nuts on the back of the cluster. When I first cranked up the car, the temp gauge immediately bounced around (appeared to me to be malfunctioning.) I wasn't sure, so I took the car out for a drive to heat it up. While i was out, the gauge quit bouncing around and shot into the red (topped out). My aftermarket gauge displayed a normal operating temperature, so this is clearly a malfunction. But at that point I'm thinking, well at least its moving. So the next day, while Im driving to work, its pegged to the red and out of nowhere it dies and drops back to the blue bottom.
Ever since then its been stuck at the bottom. It doesn't bounce around malfunctioning like it did when I first cranked up the car with the new cluster. But i did notice when is started the car this morning is just barely bounced off the bottom for a split second. Everything else in the cluster works fine, so I do not believe my SI board is dying.
What should I check now? I am kinda at a loss.
2. Anti-Lock light permanently on once key hits on position
When I installed the 'new' gauge cluster (mentioned in #1) I noticed my Anti-Lock light was staying on permanently once the key hits the on position. I think, well thats new. So i go and check my old cluster and see the bulb had been pulled from the anti-lock spot. (thanks PO for mentioning that when i bought the car... dick)
First, after researching, I find the most common cause of this symptom is a failed ABS relay. So like an idiot, i ordered a new ABS relay without checking to make sure the old one failed. I replaced the ABS relay with a new one from pelican parts. After replacing, i opened up the old one to find there was nothing wrong with it. that 'fuse' wire was not broken. Solid waste of 40$. Now I'm not sure what to check. I guess I need to check wiring and the other relays, but I don't know where they are or how to check them. Are they paired with the ECU or in the engine bay near the ABS unit? I took some picture and hoping you guys can help me identify what im looking at.
are these the other ABS relays? if not, what are they? this is located above the abs unit and next to the coolant tank
I followed some wires coming through drivers side front wheel well hole and traced them to this connector. What is this.... and should there be something attached to it? It was hiding under my fuse box.
zoom
zoomed out
what is this thing im holding. should there be additional fuses in it? When i opened it the fuse wasnt sitting firmly in the connection. (after re-seating the fuse restarting the car i saw no changes in anything)
zoom
zoomed out
