Trunk won't open, battery is dead, automatic
  • EndreM
    • Jul 2009
    • 513
    What can I do? I can't access the battery, the trunk is unlocked, but it won't open.
    '91 E30 316i
    '97 Rover Mini 1275
  • kronus
    • Apr 2008
    • 13029
    jump from the front positive distribution terminal (back passenger side of engine bay, under plastic cover) to get some power in the system.
    your trunk should be openable with a dead battery, something's goofy there.
    cars beep boop
    • EndreM
      • Jul 2009
      • 513
      I can't say that I've ever seen a positive distribution terminal on a E30. Maybe a US thing? But i'll look for it. It's a 1988 euro 325iX. Not my car, I'm just trying to help a friend.
      That's what I thought. It has central locking, but I'd imagine that since I'm able to turn the key, something is as you say, goofy.
      '91 E30 316i
      '97 Rover Mini 1275
      • future rs
        • Aug 2012
        • 514
        I don't see why unlocking with the key and pushing the key cylinder in wouldn't work with a dead battery. I have never had an issue with any of my e30's with dead batteries.
        • EndreM
          • Jul 2009
          • 513
          Now that I think about it, I don't think that I have ever owned a E30 with the battery originally in the trunk. Thanks, Kronus.
          '91 E30 316i
          '97 Rover Mini 1275
          • kronus
            • Apr 2008
            • 13029
            There's one in every rear-battery e30. Look for the battery cable coming from the back of the car, as well as the cable going to the starter. Both should end up at the distribution block.
            cars beep boop
            • EndreM
              • Jul 2009
              • 513
              You were right, Kronus. Thanks!
              Can't figure out whats wrong with the trunk though.
              '91 E30 316i
              '97 Rover Mini 1275
              • kronus
                • Apr 2008
                • 13029
                Glad to hear it! Did you get the trunk open with power?
                cars beep boop
                • EndreM
                  • Jul 2009
                  • 513
                  No. The lock pushes in, but nothing happens.
                  '91 E30 316i
                  '97 Rover Mini 1275
                  • kronus
                    • Apr 2008
                    • 13029
                    That's what it does when it's locked...
                    cars beep boop
                    • EndreM
                      • Jul 2009
                      • 513
                      Yes. I know that.
                      Maybe I explained it wrong. I turned the key, so the lock is in unlocked position, but it still wont open. I'm both norwegian and dumb, so my explanation skills aren't top notch.
                      I'll have a look at it again tomorrow.
                      '91 E30 316i
                      '97 Rover Mini 1275
                      • ForcedFirebird
                        • Feb 2007
                        • 8300
                        If you take the upper part of the back seat out, you can knock the ski-pass (if the car doesn't have one) opening through and open it from inside. Sounds like the rod may have come off the latch.
                        john@m20guru.com
                        Links:
                        • Cabriolet
                          • 9620
                          in this pic. i know it's not great but it's what i have. my dad is holding the positive end, where you need to change the car from.
                          as for the trunk. all the way right is like a dead bolt state, where the central locking cant unlock the truck. center is so that the button looks like (--) is central locking working, but locked. all the way left is unlocked and while the key is in that position try pushing the button in. if that doesnt work left the key return its self to neutral and then press the button.
                          Much wow
                          I hate 4 doors
                          • EndreM
                            • Jul 2009
                            • 513
                            I have no idea why, but yesterday it popped right up like normal. I opened and closed it a million times to see if it happened again, but it didn't.
                            Then I sprayed it with some WD40. Bitches love WD40.
                            '91 E30 316i
                            '97 Rover Mini 1275
                            • dashboardmonkey
                              FUCK YOUR WAFFLES
                              • Jun 2008
                              • 6158
                              Fuck wd-40. Use some actual lubricant on that shit.
                              -Andy
