My Headunitless Audio System Design - Input / Criticism / Advice Welcome!!
  • brian52555
    • 425
    #31
    Help... Working on the car on Sunday night now. Can't find a 12v switch in the trunk since the head unit is gone. Any recommendations?
    • StereoInstaller1
      GAS
      • 22679
      #32
      What do you want to use to turn on your radio?
      Closing SOON!
      Thanks for 10 years of fun!
      • Victell
        • 1083
        #33
        update?
        • bubbajan21
          • 1962
          #34
          Originally posted by Victell
          update?
          I just got the amp in today and I'm just waiting on my amp rack to get started. Everything should be up and running soon, Stay Tuned!
          • robo_trigger
            • 210
            #35
            So I went ahead and installed my audiocontrol lc8i based system with the rest of luke's $500 setup and the stock deck. I seem to be having major issues, My e30 headunit only seemed to have front stage wires coming from the deck and then they got split at the fader, so I ran the left and right wires directly from the headunit to the lc8i, and its definitely not getting a clean signal, or it's busted. Basically if I turn the headunit up 3/4 of the way, the lc8i will flash maximized on and off, occasionally turn off, and only barely turn the amp on, if I get noise its loud half second bursts of radio and or pops and crackles. Luke any advice?
            Should I be running the wires post factory fader (which I deleted) to the lc8i? or does it sound like it's no good? It's hard to test the system when I can't get reliable audio. I tried the aux inputs too but I couldn't get the lc8i to turn on from the aux signal.
            • robo_trigger
              • 210
              #36
              okay so here is a basic diagram. Was it a mistake to use the two channels coming from the deck as opposed to the four coming from the fader/ground splices? Also, does anyone know if the audiocontrol can make 3 line level outputs from just 2 speaker level inputs?
              • StereoInstaller1
                GAS
                • 22679
                #37
                OK..sorry, am here again, missed your post.
                Any progress since you wrote this?
                Closing SOON!
                • robo_trigger
                  • 210
                  #38
                  Yes, haha and I apologize for asking a general question and just expecting you (luke) to answer it. So I spoke with Eric at audiocontrol (very awesome guys btw) and he explained to me how the e30 in this instance should be wired.
                  For starters the stock non slider deck with only 2 channels out doesn't put out enough voltage to engage the gto (auto turn on) so you need a remote turn on, my deck's switched power just happened to have a factory splice with an unused female spade connector. So theres your power. Crack open the audiocontol and set the gto to disabled.
                  Now for sound, in order to produce three channels from only two speaker level inputs, wire the inputs to channel 3 on the audiocontrol, and once again inside the unit set all the outputs to summed. Now your front channel will be your main out, rear will be out #3, and subs will be 4. The audiocontrol will automatically reproduce the speaker signal to all 4 outputs. I suppose if you wanted to maintain the ability to fade you could leave the factory fader in the dash and just wire the 4 channels from that into the audiocontrol unit, only setting the sub output (#4) to summed but thats not what we're doing here.
                  As far as your amp, the audiocontrol can put out some serious line level volts so on something like the planet audio make sure the input sensitivity is set to 2v-8v.
                  • StereoInstaller1
                    GAS
                    • 22679
                    #39
                    Awesome! Yes...go figure I knew all of that...but i am so glad you called them.
                    See why I am so loyal to them? Aside form great products, they are great people. BTW, and old Audiocontrol product gets repaired for $35...they are awesome.
                    So...how is your sound?
                    BTW, whoever sees this, the fastest service you can get from me is either calling, texting or the Facebook German Audio Specialties page. The number is on the FB page, as is email addresses.
                    If you get stuck, get hold of me!
                    Luke
                    Closing SOON!
                    • robo_trigger
                      • 210
                      #40
                      The sound is good, I feel like I'm doing something wrong in the tuning department though. The levels seem really high, and my mids and highs arent super clean. But I've also been tuning off of the fm radio, which is silly. I think I need to install the ipod hookup to really tweak the sound. I read your amp tuning guide, but would you recommend anything different with this setup? I set the deck volume to max, then adjusted the outputs on the lc8i until its barely clipping, once I tried to set the levels at the amp though I couldn't get it to clip. Speakers disconnected so I don't blow the neighborhood away.
