Vdo oil psi problemh
  • Fernflex
    • 264
    Hello,
    I connected the oil psi gauge in my car but when the positive and negative are connected the needle goes all the way to max, when I connect the sender to the gauge it goes back to 0 but it never reads no matter if the engine is cold or hot.
    Any ideas, Im tired of searching and I don't if I need to replace de gauge or sender.
    Thanks
    Please Rate Me:
    http://www.r3vlimited.com/board/show...35#post3283535
    ________________
    1987 332i Track Car (253whp)
    __________________
  • reelizmpro
    • 9553
    Switch the ground and sender wires. If that doesnt work try another sender / gauge.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • ak-
      • 12422
      Sounds like a bad ground. There are instructions somewhere to differentiate what a pegged needle means and one that isn't.
      Where did you install the sender?
      1991 325iS turbo
      • Fernflex
        • 264
        Well the thing this was working before I swap the s52 engine into my e30.
        The sender has two pins one for the cluster light and the other one for the gauge, + and -.
        The sender is install somewhere behid the s52 oil cooler, the + is connected to the distribution block in thr front of the car passenger side and the - to the strut housing.
        Please Rate Me:
        ________________
        __________________
        • Fernflex
          • 264
          I will try this.
          http://www.egauges.com/pdf/vdo/0-515-012-178.pdf
          Please Rate Me:
          ________________
          __________________
