Help me figure out what I did wrong (yes, I searched and I'm still stumped).
I have a VDO cluster.
A few weeks ago, I removed my cluster and soldered up the grounding post connections on the board to fix a bouncy temp gauge and a lying fuel gauge. After reinstallation, the fuel gauge was fixed , but the temp gauge was still kind of bouncy and the tach and econometer were dead.
I ordered new SI board batteries and soldered them into place on a a spare Motometer SI board. I installed it with zero change. So, I removed the SI board and desoldered the batteries from it. I then soldered the batteries into the VDO SI board and installed it. No change.
I checked, pulled and cleaned the fuses. Nothing.
I tried the stomp test and nothing happened.
What else should I look for?
EDIT: I read some more. I am going to check the solder joints at the tach connections for cracks.
