Econometer Problem
  • Prost
    • Nov 2012
    • 193
    Econometer Problem
    My 92 E30 econometer is acting weird...after I start my car, it will "stuck" at the far left (40) level no matter what I do on the throttle...it will not move a bit at all. But when my speed go beyond around 70 mph, it will "swing" to the far right and stay pretty much constant at around 5. When I relax my throttle, it will swing back toward far left. If my speed is more then 70 mph, it will swing back to around 5, but if speed is below 70 mph, it will still stuck at far left (40)...what is my problem? My Tech is working fine and mt Temp gauge is also working fine...I have no clue...Can anyone share?
    92 Alpine White 325iC M-Tech II Appearance Package
  • Gregs///M
    • Mar 2012
    • 2459
    I would first suspect a damaged Si board, see my thread on Si board damage. Next guess would be dying SI board batteries. Lastly, I would suspect a bad motor for that needle.
    Owner - Bavarian Restoration
    BMW and European Electronics Repair and Restoration
    www.BavRest.com
    My Feedback Thread
    Our Facebook!
    Follow our Instagram!
    • Prost
      • Nov 2012
      • 193
      SI board checked and no problem and battery had been replaced, bad motor I am not sure since it is moving but just weird...thanks
      • Gregs///M
        • Mar 2012
        • 2459
        Did you check for damage on the inside corners of the board?
        www.BavRest.com
        My Feedback Thread
        Our Facebook!
        • Prost
          • Nov 2012
          • 193
          I don't understand...could you explain in more details? Pic?
          • Gregs///M
            • Mar 2012
            • 2459
            www.BavRest.com
            My Feedback Thread
            Our Facebook!
