High pitch noise from speakers related to rpm
  • JonnyOg
    • Sep 2012
    • 191
    Yea so as my title says I'm getting a high pitched noise from my speakers thats related to my rpm, as in it gets higher and the rpm increases. Seems to make no difference with the deck being unplugged.
  • bmwman91
    • Oct 2004
    • 3134
    Is this with stock equipment or aftermarket? If you are running an amp in the trunk and it pulls the input from the speaker wires, that probably has something to do with it.
    Transaction Feedback: LINK
    • JonnyOg
      • Sep 2012
      • 191
      It still makes the noise with the rcas taken out of the amp, and with the deck unplugged. What do I check next?
      • AndrewBird
        The Mad Scientist
        • 11898
        I'm assuming at this point you have an aftermarket head unit and amp.
        It makes the noise with the amp turned off? You have bypassed the stock amplifier, correct?
        • JonnyOg
          • Sep 2012
          • 191
          Didn't have a factory amp. Did the install the way luke does for installing a 5 channel and sub in a non premium car . Only recently started making the noise.
          • 5m1dy
            • Sep 2012
            • 13
            Its something to do with the amp picking up the frequency from the ignition system and then amplifying the noise. There is some sort of noise filter you can buy and install on the inputs to the amp which should cut that sound out. I'd also maybe try grounding the amp at a different spot.
            • ejnight
              • Apr 2007
              • 3488
              check your grounds.
              http://raceskids.com/
              • AndrewBird
                The Mad Scientist
                • 11898
                If it didn't used to do it and started suddenly, I'd bet a ground strap has come loose somewhere.
                • JonnyOg
                  • Sep 2012
                  • 191
                  Yea it seems to have gone away.. I checked the ground for my amp its it's still solid.
                  • Maroulesj
                    • Apr 2012
                    • 206
                    I've got the same problem , Po had an amp in the back I think it just had a loose ground somewhere, I haven't had a chance to look at it. When I drive it sounds like a have a supercharger :)
                    James A. Maroules
                    Cell: 201 587 6565
                    • StereoInstaller1
                      GAS
                      • 22679
                      Most of the time with modern equipment if you have alternater whine, it is bad cable routing.
                      First thing to do is make sure all signal goes up the left side of the car. Once that is certain, check your grounds. I HIGHLY recommend either making your own ground point or using the factory ground point (rear battery cars only).
                      GL, and LMK if I can help
                      Luke
                      Closing SOON!
                      Thanks for 10 years of fun!
                      • LittleEcker
                        • Oct 2012
                        • 83
                        Same problem here.
                        The stereo is aftermarket and I haven't checked for loose grounds yet. Guess that's the first thing to check, huh?
                        -Experience is what you have right after you need it
