Lately, I've noticed that when I switch the ignition on in the morning (first start), the car would start, if I just leave the car on idle, the indicator lights i.e. battery, brake lining, and oil (No ABS indicator) on the cluster won't switch off. But if I rev it a bit, then it would go out as it should, normally.
Together with it, the power locks do not operate consistently. Sometimes, the locks would not open on the other doors i.e. passenger doors, gas tank, trunk, at times it would work perfectly fine.
We've had a bit of rain the past week, and was just wondering if this happens if some of the parts get too moist and corroded, but I'm unsure what to look for.
I'd appreciate it if anyone can share their experience. If so, what is it indicative of? A dying battery, corrosion, grounding, or what not...
Thanks!
Thanks!
