I have looked around a bit, but i'm unsure exactly how to troubleshoot my speedometer so that I know what's wrong with it. I am currently restoring my 91 325ix, but after letting it sit for about 2-3 weeks with the battery disconnected (i'm installing a new stereo), the speedometer no longer registers my speed no matter how fast the car is moving. It worked just fine the last time I drove it (the day I disconnected the battery), but suddenly quit working. Is there a way I can troubleshoot what is causing the problem? Is the problem obvious and i'm just not seeing it? Any help is appreciated.
How to troubleshoot speedometer?
fusesOwner - Bavarian Restoration
BMW and European Electronics Repair and Restoration
www.BavRest.com
My Feedback Thread
Our Facebook!
Follow our Instagram!
Welcome to the forum. Where in the midwest are you?
What else have you molested? Did you disconnect the OBC when installing the radio? Did you remove the speedometer from the cluster? The pins are delicate when plugging it back into the main circuit board of the cluster.
First follow Gregs///M's advice and check fuses.
Then unplug and plug back in each connector on back of cluster.
If all else fails, try a different speedometer in the cluster.
The lack of stereo will not effect the speedometer.
I was going to give my opinion but then saw Gregs///M had replied...lol
Sent from my Galaxy Nexus using Tapatalk 2sigpic
Rebuilding since 07/06/2016
Poorboyz Parts For Sale - Updated 01/20/17 - Will be updated soon - Have many parts to post
Poorboyz Feedback Thread
