Tach/OBC both stopped working
  • BMWManiac
    • Dec 2010
    • 1091
    Tach needle doesn't move at all, but the boost needle in place of the standard mpg guage moves. The light bar on the OBC lights up, but no values.
    I checked fuse 10/21, both are good. Woke up one morning, took about 6 times to start the vehicle. Other than that, they worked when I parked the car the night prior....very next morning, they stopped working?
    1997 Artic Silver M3
    CES GT4094r 651hp/615tq @ 24 psi
  • Gregs///M
    • Mar 2012
    • 2459
    Replace fuses 10, 12, and 21.
    Owner - Bavarian Restoration
    BMW and European Electronics Repair and Restoration
    www.BavRest.com
    My Feedback Thread
    Our Facebook!
    Follow our Instagram!
    • reelizmpro
      • 9558
      Try tapping the top of the dash above the cluster and see if it turns back on. Works for me...
      88 M3 - LACHSSILBER
      89 M3 - ALPINEWEISS II
      • BMWManiac
        • Dec 2010
        • 1091
        I did try tapping the dash, and nothing happened....I'll replace all 3 x fuses and go from there when I get home next week!
        • BMWManiac
          • Dec 2010
          • 1091
          Swap'd in another tach into my cluster and the tach didn't work. Put in that tach into my spare cluster and the tach then worked....looks like the IS board is causing the issue? The OBC worked too....good thing I bought a refurbished one from you, Greg!
          Tach is on it's way to you today!
          • e30rapidic
            • 2167
            SI board/batteries failure.
            '87 325ic, powered by S50.
            • izickc
              • Feb 2013
              • 59
              Post if u figure this out, ive put in 3 clusters and none worked
              Sent from my SAMSUNG-SGH-I337 using Tapatalk
              • BMWManiac
                • Dec 2010
                • 1091
                I thought I did? Must be the SI board in the cluster....
                • izickc
                  • Feb 2013
                  • 59
                  I've replaced.the batteries in mine, still no luck!
                  • BMWManiac
                    • Dec 2010
                    • 1091
                    I would swap out the board itself....there could be a broken electrical weld somewhere
                    • izickc
                      • Feb 2013
                      • 59
                      Ill give it a shot
