Replacement headunit options that suit the E30 interior
  • Vincenze
    • Apr 2019
    • 1038
    #241
    Here is the manual for Blaupunkt Bremen SQR 46
    • quasi mofo
      • Dec 2016
      • 107
      #242
      Originally posted by m5james
      Flame suit on...but the GF loves it and I do as well.
      Joying 10.25" Android stereo powering RF speakers throughout, eventually it'll get a small sub enclosure w/ a matching RF monoblock amp. This killed multiple birds w/ one stone...beforehand it had an outdated CD player w/ no bluetooth, OBC screen has a leaking LCD but it's not like we used it anyways. This has better fitment that the one I'm running in my E36 in that hers doesn't block the heater vents at all and the width matches perfectly with the dash.
      Really close to pulling the trigger on this. My car came with a Kenwood Excelon KDC X-998... how difficult was the install/stereo swap for you?
      • m5james
        • Feb 2012
        • 59
        #243
        The wiring was similar to any other stereo...the screen mounting on the other hand was a different story. These screens are originally intended to mount with tabs that have about 2" of adjustment in any direction, but I went much further for aesthetics sake and had to epoxy the mounting tabs on in different locations. I also tilted the screen upwards a bit for better visibility. I'm at work currently but I can try to remember to take pics this evening if you'd like. Envisions |\ wedges like such that were epoxied between the tabs and the backside of the screen itself...took a few hours of cutting, sanding and then used 5 min epoxy but it worked out great and is improved from the original picture now that the screen is tilted slightly upwards.
        • quasi mofo
          • Dec 2016
          • 107
          #244
          Thanks! My car is getting a new headliner installed right now so I don't have access to it. Need to pull the stereo and figure out what kind of iso adapter I might need. The Joying stock adapter looks very different from a Kenwood harness plug.
          • Rev Run D
            • Feb 2013
            • 392
            #245
            Originally posted by Victell
            I'm considering no head unit and just using a Bluetooth amplifier to reduce components and wiring. I listen from my phone most of the time and rarely listen to terrestrial radio. There's several of these type amps out there but this JBL GTR-104 might be good. Plus a radio block-off plate.
            • 240 watts RMS x 2 bridged
            • wired remote unit has controls for Bluetooth streaming, hands-free calling, party mode (multiple simultaneous Bluetooth connections)
            • preamp and speaker-level inputs
            Click image for larger version  Name:	E30 RADIO BLOCK OFF PLATE.jpg Views:	380 Size:	53.4 KB ID:	9882044
            plus
            Click image for larger version  Name:	GTR104a-600x600.jpg Views:	390 Size:	23.7 KB ID:	9882043
            Ever do this? Looks like its NLA.
            • eternal24k
              • Jul 2017
              • 507
              #246
              I would be down if there was a skip button, pause, and power knob.
              • Rev Run D
                • Feb 2013
                • 392
                #247
                https://www.crutchfield.com/p_113M18...BT.html?tp=115
                Looks like this one is.
