E46 window switches with one touch function
  • ajune
    • Jun 2013
    • 36
    Thanks :D I'm working on building a test 555 circuit right now to act as the trigger for the SPST relays :-)
    • ajune
      • Jun 2013
      • 36
      For now I've built the 555 timer circuit but I need to adjust the timing of it to generate a longer signal pulse. Currently the pulse only lasts for ~0.1 seconds... -_-
      • ajune
        • Jun 2013
        • 36
        Originally posted by stonea
        Although I dont understand any of this, its still a pretty cool project, cant wait to see it finished.
        Built my test circuit (555 ic timer) to test for activation and timing pulse length to use for auto up/down & vert window actuation (like in modern certs and half door cars with automatic window drop when you open doors and raise when you close them for sealing purposes). I'll use it to activate a pair of SPST (single pole single throw) relays to power window motors.
        Currently its built with a test diode to be run by 9VDC, but I will be adding the 5VDC voltage regulator later when I add it to a 12VDC test circuit. Surprisingly simple as far as switched circuits go that essentially use low voltage to drive high voltage circuits. Once its finalized I'll map out a PCB circuit and etch it, install the components and build an enclosure with all components required to run four windows all with auto open/close on them and adjustable timing length and over voltage protection for the entire circuit in case someone gets their hand stuck in the window it will cut power instead of just pinning it helplessly.
        • Mr. Tasty
          • Jul 2011
          • 3421
          very cool
          2014 Alpine White 335i MSport
          (Daily Driver)
          Full Mperformance Aero
          KW V2 Coilovers
          VRSF Catless Downpipes
          • stonea
            • 2892
            Any progress on this?
            My Garage
            Feedback
            Instagram: Stone.Hopkins
            • madman23
              • Jan 2007
              • 498
              Hey. Just wondering if this was finished? I am looking at diing this myself.
              • george graves
                • 20003
                Since OP was using a 555 timer, it's really not the best plan of attack for something like this. Windows roll up a bit faster in the summer, when your battery is at a higher voltage (just was getting charged from driving and is at 13 volts vs sitting for 2-3 days and at 12 volts) and when well lubricated. So with a timer circuit, you have to say "Ok, the max time it takes to roll up the window? Ok 7 seconds, lets add 3 seconds to that to cover every situation"
                So, it can work, but it's like parking a car in one of those car lots with the concrete curbs between each parking space. It would be like if you said "ok, let's drive the mini van up to it, and when we feel it hit, keep your foot on the gas for an extra 3 seconds, just to make sure!"
                It add extra stress to the window motor and the switch, and in some conditions might not let the window fully close.
                The better way of doing it is to measure the current going to the motor. It's how it's done on just about every car from the factory, regardless or make or model.
                Originally posted by Matt-B
