gauge cluster acting strange
  • mario23_15
    • Nov 2013
    • 11
    When I start the car, the tach sweeps to 7000 rpms and stays there until the car warms up then it'll bounce around a bit, then falls to zero and stays there acting as if it doesn't work at all.
    The speedo and fuel gauges don't work at all.
    The temp gauge seems to work fine.
    Any ideas on what's causing these cluster problems?
    Here are a couple pictures. The first shows the tach at start up
    This is after the car is warm
  • reelizmpro
    • 9558
    Pull it out and check the tach and main pcb for shorts and breaks. How are the si board batteries? Looks like an 84 318I cluster.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • Gregs///M
      • Mar 2012
      • 2459
      You most likely have leaky batteries that has caused the logic to get all wonky. You'll most likely need to replace the cluster and if your lucky, only the SI board.
      Also try changing fuse 10, 12, and 21 and some of your gauges might work again.
      Owner - Bavarian Restoration
      BMW and European Electronics Repair and Restoration
      www.BavRest.com
      My Feedback Thread
      Our Facebook!
      Follow our Instagram!
      • mario23_15
        • Nov 2013
        • 11
        Thanks for your input, guys.
        I changed out the fuses first and still nothing. So I decided to tear into the cluster. Here are some pictures. Overall, I believe the board looks good (to my untrained eyes of course).
        I'm assuming the 94-07 is the expected life on the batteries? So they're most likely dead.
        I then found it was a motometer board in a vdo cluster (not sure if it really matter)
        • Gregs///M
          • Mar 2012
          • 2459
          Well you have a modern SI board in an early style cluster so that is great. You probably just need to replace the SI board batteries.
          We have these boards in stock, ready to ship. Just pay for the core price and it will get refunded when you return your original SI board.
          www.BavRest.com
          My Feedback Thread
          Our Facebook!
