As part of my turbo setup I'm in need of extra power for the gauges, gauge lights, intercooler fan, and intercooler sprayer. The IC stuff technically doesn't need to be switched 12V, but the gauges do. Rather than adding 4 separate circuits with 4 in-line fuses, I purchased a small distribution block and 6-circuit fuse block. This way I can keep all my new circuits/fuses in 1 place (probably in the glove box area) and simplify some wiring. My question is, what's the best way to feed this distribution block with roughly 30A worth of switched 12V power? Is there a good source for that much amperage already, or should I consider pulling straight off the factory distribution block on the firewall (where the battery cable comes in) and putting in a relay to make it "switched"? Thanks for the help!
How to add 30 amps worth of switched 12V power?
Tags: None
I suggest you pull your new power from the distribution block on the firewall using a minimum of 4AWG cable. Alternatively, you may take it directly from the battery which is the best place but more difficult.
For your switched sources, you will have to use relays for any HEAVY electrical load systems.
Don't forget to add a fuse coming from the dist block or battery.
Good luckOwner - Bavarian Restoration
BMW and European Electronics Repair and Restoration
www.BavRest.com
My Feedback Thread
Our Facebook!
Follow our Instagram!
30A for gauges? pretty overkil, but definately want to pull power from dist block and just give it a relay switched 12v signal to power it on and off. Car stereo circuits in most cars run off shared circuit with many other lights and whatnot and only have 10A. 4AWG as mentioned above would be rite for real 30A draw, but in reality you wont be pulling that much power, so 10AWG is going to be more than enough.IG: @Baye30
FRONT VALENCE IS ZENDER!!! STOP FILLING MY PM BOX PPL!!!Comment
I say 30A because that's the total power going through fuse block, so the feed needs to be able to hand that much.
My thought is to do it like this: firewall distribution block -> 30A fuse -> relay -> distribute in to fuse block -> fuse block -> separate out in to 4 circuits for various needsComment
How about a starter solenoid / relay for a garden tractor? or one of these http://www.hifisoundconnection.com/S...3CvxoCQVHw_wcBFS NY: two Audiobahn A235HC amps and audiobahn 1farad capacitor
Saab/GM tech2 programming
My for sale thread
1990 325iX for sale or part out
Did you buy something from me? Please leave feedback!
Originally posted by K20RI_211And I have to ask if you make a hobby out of thread-bombing with retarded questions?
