Which wire to get power from?
  • kdisjubjub
    • Mar 2015
    • 17
    Can I tap into any of these wires to hardwire my radar detector?
  • Ether-D
    • Sep 2011
    • 2838
    Put a volt meter on them and see. You can doit!
    Originally posted by Andy.B
    I was born on 3/25…
    • StereoInstaller1
      GAS
      • 22679
      Yes, use sunroof power, at the switch is easiest
      Closing SOON!
      Thanks for 10 years of fun!
      • kdisjubjub
        • Mar 2015
        • 17
        Do you know which wire this would be? I don't have a volt meter at the moment.
        • barbierij
          • Sep 2012
          • 1294
          any e30 owner should have a volt meter. harbor freight sometimes has a coupon for a free one.
          FS NY: two Audiobahn A235HC amps and audiobahn 1farad capacitor
          Saab/GM tech2 programming
          My for sale thread
          1990 325iX for sale or part out
          Did you buy something from me? Please leave feedback!
          Originally posted by K20RI_211
          And I have to ask if you make a hobby out of thread-bombing with retarded questions?
          • kdisjubjub
            • Mar 2015
            • 17
            Just got the car last month and went on a two week vacation so haven't had time to get all the stuff I need.
            • Mac_86ES
              • Feb 2013
              • 21
              I wouldn't use any factory wiring because you're on the draw side pf the fuse and are more likely to blow fuses unnecessarily. I put an accessory fuse block under the hood. If you want it on ignition use a relay and tap the ingition feed wire from the car. But I wouldn't use the factory wiring its easier but it always better to put the time in to do it right.
              • StereoInstaller1
                GAS
                • 22679
                It's less than a 1a draw on a 30a fuse, no need to run wires, this isn't some POS Civic....
                Closing SOON!
                  • 34827
                  besides that, the E30 comes with a factory accessory fuse block. there's no need to add extra wiring, things like that are why so many of these cars have screwed up wiring. The stock wiring is actually really nice - remember, these cars were built before the day the bean counters took over from the engineers at BMW.
                  • kdisjubjub
                    • Mar 2015
                    • 17
                    So doing an Add a Fuse will be the best option for me? Radar detector is needed in this car haha.
                    • StereoInstaller1
                      GAS
                      • 22679
                      If you feel you can run a wire through the firewall without creating waterleaks, you can run a wire from the auxilliary fusebox under the hood, but there is no need to do so. The sunroof power wire is a nice fat wire, carries plenty of power and is separately fused...running a tiny little load like a radar detector is nothing...so basically, if you have the skills to run all that way to the fuse block, go ahead, but there is absolutely no need to.
                      Oh, pretty sure it's green/blue, but test it to make sure.
                      Luke
                      Closing SOON!
                      • Garrick2007
                        • Jun 2014
                        • 59
                        Was just thinking yesterday about doing this eventually when I get one, post photos of the finished instillation if you can.
                        • kdisjubjub
                          • Mar 2015
                          • 17
                          Luke
                          The PO took out a lot of the plugs in the fire wall so I have a lot of options to run the wire through. I'm going to try the add-a-fuse option and see how that works. Anyone know which fuse I should tap into?
                          • StereoInstaller1
                            GAS
                            • 22679
                            Which ever one turns off with the key
                            Closing SOON!
