Keyless Entry REC-43T
  • Dice_980
    • Apr 2015
    • 10
    Hello all, I installed the Omega Research Keyless Entry REC-43T and only the lock button works unlocking doesn't work, I replaced the central locking control unit with others that i had laying around but that didn't help and i tried wiring it through the front driver side by the kickpanel but still nothing. Has anyone had this problem and fixed it?
  • E30 331is
    • Sep 2011
    • 1166
    I have installed similar devices including the REC-43T using the trunk actuator using the power from the antenna.
    http://bmw.e30tuner.com/articles_rec43t.php
    • Dice_980
      • Apr 2015
      • 10
      Exactly how i set it up, I have this same unit installed in my 91' 318i and it works perfectly so i swapped unit to make sure it wasn't the unit and unit works fine. Its just the unlock cable not seeming to work.
      • E30 331is
        • Sep 2011
        • 1166
        Reversed polarity? I dunno. Good luck!
        • reelizmpro
          • 9558
          Double check your unlock splice. Probably a bad connection.
          88 M3 - LACHSSILBER
          89 M3 - ALPINEWEISS II
          • Todd Black 88
            • Oct 2007
            • 3449
            Make sure your drivers door lock is not double locked
            Originally posted by codyep3
            I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
            2001 silver/Blk 325 cabby. SOLD
            2002 325xit Sil/blk. SOLD
            2010 F650gs twin
            • audiquattrot
              • May 2008
              • 3836
              Follow the directions on how to reset and program the buttons. I don't remember exactly but I know there is a sequence of presses on the module and the key fob u need to do in order to get the key fob to mate up. Took me dozens of times and finally got it to pair....if it doesn't work w one fob, try it w the extra one they gave u
              www.instagram.com/snwmble
              #snwmble
              Current:
              '05 BMW M3 - Silver Grey/Imola Red
              '90 BMW 325iX - Sterling Silver/Houndstooth sport(5-speed converted)
              '15 Mini Countryman - Blazing Red/Carbon Black
              Past:
              '01 Audi Allroad - Light Silver/Platinum Saber Black
              '88 BMW 325iX - Diamond Schwarz/Silver sport *Sold*
              '01.5 1.8TQ - Brilliant Black/Nogaro Alcantara ...after 8.5yrs, *Sold* =(
              '90 BMW 325i - Schwarz/Tan sport *Sold*
              '89 BMW 325ix - Diamond Schwarz/Black sport *Sold*
              • 330SMG
                • Feb 2007
                • 172
                Have the same one. Usually the connection on the unit is loose. make sure the unit is mounted secure and there is no strain on wires. I hope you did it correctly and put it under the dash right by the module.
                1989 Cirrus Blau coupe Racing Dynamics wheels and a Volvo Spoiler.
                • bmwman91
                  • Oct 2004
                  • 3134
                  Wow, good to see that people are still using my how-to article.
                  OP, did you mess with any of the little switches on the REC-43T? IIRC, the default position that they are in when you get the unit is the correct one. Also, as mentioned above, make sure that the double-lock is not engaged on the driver's door or the trunk.
                  Transaction Feedback: LINK
