Scyteck Astra A20 alarm install
  • Staszek
    • 2533
    So I searched and read through a lot of threads, my brain doesnt always work so great when it comes to wiring, never been my strong suit.
    I am trying to figure out how many relays I actually need.
    I know I need one for the door locks since my alarm is only 500ma.
    I have the OEM light control module relay, can I just tap that for the dome lights?
    Do I need a relay for the blinkers, or can I use two Diodes to make it cleaner?
    I found this diagram on here that I was planning on partially following.
    Here is my wiring diagram
  • Staszek
    • 2533
    Anyone?
    • 84driver
      • Aug 2011
      • 234
      Diodes for the parking lights. I'm pretty sure you can use the OEM dome light relay. I made that diagram but that was 4 years ago so I'm a little rusty. It's actually easier than it looks.
      Short answer: just two relays for the locks.
      balticblau-metallic '84 318i 5spd 3.91 LSD
      • Garrick2007
        • Jun 2014
        • 59
        I did a partial follow on that diagram too while using a few other sources, came out perfect, i even wired up a modern clown nose mirror so u could use its light rather then the stock one, came out really good, if interested: http://www.r3vlimited.com/board/showthread.php?t=360401 If your not happy with that alarm check out the Viper 5305V Such a dope alarm for only $100 on amazon.
