Radio display broken?
  • Gkwan
    • Sep 2015
    • 82
    Today I tested my stock radio that I picked up a few weeks ago to replace the after market radio that was installed by the previous owner.
    When I started it up, the display was blank! All of the lights appear to work and the back light is there but there is no text showing the station or anything else.
    Is my display broken? Can this be fixed??
    Thanks!
  • E30islifestyle
    • Sep 2015
    • 6
    can you shoot close picture?
    does anything happen when you lightly press on the display?
    • dlmpsy
      • Sep 2006
      • 189
      If the code didn't work, and you reset the radio and entered the code correctly, then something else may be going on. You can get these radios refurbished for about $145.
      • 15Michaeljoseph
        • Aug 2013
        • 1693
        How do they go about refurbishing? I have a stocker with harness and when I quickly hooked it up it wouldn't even turn on :(
        --Mike
        (OO=[][]=OO) For Life
        • AndrewBird
          The Mad Scientist
          • 11898
          I would never pay $145 to refurbish a factory stereo. So many good used one out there for practically nothing. Not to mention 100's of better aftermarket options.
          What does it look like with the headlights off?
          • dlmpsy
            • Sep 2006
            • 189
            Here are some places that do refurbs...with a warranty. As far as stock or aftermarket that's your call. I like my original factory radio and the ability to have weather stations.
            • Gkwan
              • Sep 2015
              • 82
              Thanks for the links, might see if those guys know anything about this problem
              For reference here is a close up picture. When the radio is off, nothing shows on the display.
              • profbooty
                • 308
                Any audio?
                Mine has no audio, but lights up just like that. Code light isn't on either.
                • Gkwan
                  • Sep 2015
                  • 82
                  Originally posted by profbooty
                  Any audio?
                  Not sure yet, the previous owner cut all of the connectors, I have new ones but haven't spliced them in yet. Also somewhere along the way the amp in the back got lost, along with the connector so I haven't had a chance to test the audio yet.
                  • PieterVN
                    • Nov 2020
                    • 72
                    Did you found a solution for this problem? My radio has similar issues only it does work sometimes. Other times it's just the backlight that lights up and nothing on the screen.
                    Belgian E30 Driver
                    1990 - E30 - 318i Cabriolet Brilliantrot
                    /// 1988 - E30 - 320i Touring Diamantschwarz (Sold)
                    /// 1990 - E30 - 318IS Coupé Lazurblau
                    Check out my Rare BMW Music Edition Cassettes Topic
                    • Gregs///M
                      • Mar 2012
                      • 2459
                      There is not much to the radio, power, ground, antenna output, speaker output. If your radio powers on and the display does not work, your radio is bad, plain and simple.
                      Owner - Bavarian Restoration
                      BMW and European Electronics Repair and Restoration
                      www.BavRest.com
                      My Feedback Thread
                      Our Facebook!
                      Follow our Instagram!
