no windows or headlights on 24v swap
  • shayne_bermudez
    • Nov 2013
    • 78
    got to tidying up everything on my 24v swap and came across a problem with my headlights.
    when i go to pull the highbeam stalk twords me to flash my highbeams the realy clicks but there is no power going to the headlights. i also dont have any power windows.
    cant see if low beams word because i broke the switch to control them
    E30s for life. will drive nothing else than a BMW.
  • Sea Aych
    • Apr 2013
    • 764
    Does your car start?
    Check your pinouts if not - I had no windows and the car wouldn't start, and my body harness pins 7 and 15 were wired into the the wrong engine harness wires. Keep in mind this is for an M50 OBD1 (It should be 7(body)-->21(engine) and 15-->15. I had 7-->15 and 15-->21)
    Just a shot in the dark, but who knows
    1988 Atlantisblau Euro/Japanese 325i Cabriolet
    1989 Schwartz 325i - now M50 powered! - now very dead
    1998 Toyota 4Runner Limited
    My 17,000km Big NA National Parks trip!
    • shayne_bermudez
      • Nov 2013
      • 78
      yep car starts and runs fine. Someone said something about a green and black starter wire that should be grounded? an unloader or something? im not the best with electrical but im pretty sure my harness wiring is ok.
      • Das Delfin
        • Sep 2014
        • 2293
        Fix the low beam switch first...
        • Manny
          • May 2016
          • 4
          I am having this same problem, no power windows, no headlights and car wont start. But I dont have a swapped engine, its the stock m20 engine. However, fusebox got replaced due to a short and ever since the car has this issue.
          I am new to this and need some help. When you mention "pins" where exactly are they located?
