Left turn signal goes into high beams
  • SoCal_e30
    • Mar 2016
    • 70
    Hello all, don't know if this is a common e30 thing but I've recently replaced my lever because I though my lever was the problem. Last night I had the same problem where if I use the left turn signal after a few seconds it falls into high beams. It's just annoying to others and could possibly get me in trouble with the police out here.
    Any help would be appreciated. Thanks in advance :)
  • reelizmpro
    • 9543
    It is common. Are you sure the new switch was working properly? Is so, maybe there's a short in the wiring. Most of the time it's the turn signal switch though.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • SoCal_e30
      • Mar 2016
      • 70
      It was the switch. Couldnt figure it out so I went full savage, just cut the yellow high beam wire and problem solved lol I only have the high beam flash now. Sooner or later I'll repair it even though we really have no use for constant high beams here in sunny California.
