Humming noise from speakers.
  • ironshmoobs
    • Apr 2016
    • 12
    I'm going crazy trying to figure this out. I took my E30 318i to go get a Kienzle MCR-1016 BT installed, the guys at the shop told me that they did all of the wiring, but that I have a bad radio, because its brand new and I've not seen any reviews where this has happened, but the guys that installed it said there is no output. I honestly highly doubt its the radio, because days before I took it in my friend and I tried to install it ourselves we put the negatives together and I forgot what we connected them to, but a little sound came out, and after that we couldn't figure it out. Now, after I took the radio to get installed and I turn the radio on all I hear is a humming noise like if the speakers are on, but no actual music comes out. I hope you guys can help me figure this out, because its driving me crazy.
  • Gerta
    • Sep 2009
    • 2119
    Sounds like it might be the radio. You may have damaged the radio with by connecting both the negatives? Swap in another radio ... grab one from Craigslist, etc .. for cheap as your test unit if you cannot buy one.
    Then check out the stickies in this section .... lots of good info there.
    Parts Collector and Former Houndstooth interior junkie.
    • Das Delfin
      • Sep 2014
      • 2293
      That is a neat looking radio!
      radios are really easy to install. I doubt the shop did anything to mess it up. I would look into doing it yourself next time because all you have to do is match up wire colors. It's really easy.
      • DER E30
        • Sep 2013
        • 2349
        Does it have an amp with RCAs? If you plugged in your RCAs while on you can burn some little resistor that grounds the RCAs out... You've gotta ground the ends of the RCA separately then, I forgot where but somewhere I have a pic of mine with a wire tying them all together and grounding them out
        -Christian
        • straight6pwr
          • Sep 2004
          • 3450
          you tried to wire it (not knowing what you were doing) and it did then didn't work?
          definitely a possibility you broke something.
          • DER E30
            • Sep 2013
            • 2349
            Broke a ground internal to the hu
            -Christian
