CM5908/5907 Plug-n-Play Bluetooth upgrade board
  • bradnic
    • Jul 2012
    • 3554
    #31
    Count me in for 2 boards.
    HOWTOs:
    DB vert plastic bumpers
    OEM Keys
    MTech1 docs
    88 ix Lach/Card
    91 ic Calypso 3.1
    86 Cosmo 2.7
    OEM+ or bust!
    • djjerme
      • 5082
      #32
      Did someone confirm that the 5903 has the same mechanism?
      2016 Ford Flex
      • Chrisbike
        • Mar 2015
        • 688
        #33
        Update us!
        Build Thread
        https://www.r3vlimited.com/board/sho...d.php?t=419655
        Parts Thread
        https://www.r3vlimited.com/board/sho...d.php?t=408302
        • jaysterling
          • Sep 2016
          • 59
          #34
          Still working on it! Been super busy with work lately working long hours, so time on this has suffered, but certainly not stopped. It's also been a real PITA working with this CSR chip. I've pretty much figured out its quirks at this point but for awhile I was having huge troubles reliably reading/writing the EEPROM that configures the BT chip and (now I realize) mistakenly thought I kept frying the chips.
          Anyway, my hope is to get a video up this weekend of it working. Pretty much all the buttons are doing the right things now according to that original faceplate pic I put up. Mic input and phone calls are working. The last thing I have to work through is the analog audio out. I've got it working, but there is digital noise in the output that's higher than I'd like, so next I'm seeing what I can do to eliminate that. The BT chip has differential outputs, then I'm using a TPA6132A headphone amp for the single-ended conversion. When I plug the output of the chip into headphones, the SNR is great, but when plugged into the stereo, the digital noise is present. I'd guess it's like -50 dB down from full scale signal, but it's there. I'm going to try running a separate 3.3V regulator just for the headphone amp with a separate ground path from the rest of the circuit, but any advice is appreciated :)
          • bradnic
            • Jul 2012
            • 3554
            #35
            you are powering the whole test rig with an actual battery and not a power supply right?
            HOWTOs:
            OEM Keys
            MTech1 docs
            88 ix Lach/Card
            91 ic Calypso 3.1
            86 Cosmo 2.7
            OEM+ or bust!
            • jaysterling
              • Sep 2016
              • 59
              #36
              No, I'm using a bench power supply currently. I figured power could only get noisier running on the alternator in the car, so I should get it at least working in the ideal case first. Bad idea?
              • bradnic
                • Jul 2012
                • 3554
                #37
                it probably introduces noise. best to try a battery source to make absolutely sure.
                HOWTOs:
                OEM Keys
                MTech1 docs
                88 ix Lach/Card
                91 ic Calypso 3.1
                86 Cosmo 2.7
                OEM+ or bust!
                • jaysterling
                  • Sep 2016
                  • 59
                  #38
                  Turns out using a separate power supply and ground path totally fixes the digital noise issue like I hoped.
                  So it's all working now! I just made a short demo video with everything buttoned up inside and functioning. Still work to go but it's getting close.
                  • s1uma1
                    • Sep 2015
                    • 304
                    #39
                    Omg. This is so freakin' awesome. Please please please please tell me you're gonna sell this... please please please...
                    • bradnic
                      • Jul 2012
                      • 3554
                      #40
                      Home run brother. Ready to paypal you for the units i requested earlier
                      HOWTOs:
                      OEM Keys
                      MTech1 docs
                      88 ix Lach/Card
                      91 ic Calypso 3.1
                      86 Cosmo 2.7
                      OEM+ or bust!
                      • Chrisbike
                        • Mar 2015
                        • 688
                        #41
                        Build Thread
                        Parts Thread
                        • Eric
                          • 5142
                          #42
                          I'd like one of these, how much?
                          • Boggie1688
                            • Nov 2016
                            • 52
                            #43
                            Jay, sent you a PM.
                            • Todd Black 88
                              • Oct 2007
                              • 3449
                              #44
                              Beautifully executed.
                              I am in for a few I think.
                              Originally posted by codyep3
                              I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
                              2001 silver/Blk 325 cabby. SOLD
                              2002 325xit Sil/blk. SOLD
                              2010 F650gs twin
                              • tuckerware
                                • Mar 2017
                                • 87
                                #45
                                Most days I feel like a fairly intelligent person until I read a thread like this and feel like a moron. I mean, amazing accomplishment but stop showing off already. ;)
                                So, even though you are kind of being a dick by making us look like comparative neanderthals I really would like to give you money now for this witchcraftery.
                                Is it ready yet?
                                How about now?
                                1989 BMW 325is Coupe - Alpine White
