CM5908/5907 Plug-n-Play Bluetooth upgrade board
  • bradnic
    • Jul 2012
    • 3554
    #46
    Lulz
    HOWTOs:
    DB vert plastic bumpers
    OEM Keys
    MTech1 docs
    88 ix Lach/Card
    91 ic Calypso 3.1
    86 Cosmo 2.7
    OEM+ or bust!
    • jaysterling
      • Sep 2016
      • 59
      #47
      Hah, thanks everyone :) So I went out today to verify everything worked with the CM5907 since I naively claimed it would work, and I realized an issue - it's not quite the same. The physical foot print is the same, but the flex cable actually has 2 fewer traces than for the slider radio. I dug in and found the signaling scheme for the user inputs are actually totally different on the flex for the 5907. It should still be possible to have 1 board that works for both, but it's just work I wasn't expecting. It will also mean that for the 5907, you would have to slide the flex cable to one side in the connector before tightening the latch since it's narrower.
      I guess I should ask though: is anyone actually wanting to use this in a CM5907/CM5905? It's a bit more work to install it into one of these and it will unfortunately require enlarging a hole in the top/side for a mic plug and removing the cassette deck requires desoldering a dab of solder on a (easy to access) screw inside.
      But to answer a few questions:
      Am I planning on selling them?
      Yes
      When will they be ready?
      Hard to say, but this is roughly what still needs to happen:
      1. Finish PCB layout for the (hopefully) final version.
      2. Have 1 printed, hand assemble (week fab lead time, then assemble)
      3. Validate on the bench
      4. Install in my car, use it for at least a week, working through anything new I find
      5. Rev board if needed and print a few more for a small beta test. (I've had some interest already, anyone else wanting to be a beta tester, esp. if you're local, PM me)
      6. Work through any issues from the beta test (probably a few weeks)
      7. Meanwhile, begin taking orders and working with whatever Chinese fab/assembly house for the initial production run. Lead time on this can be 4-5 weeks.
      Realistically, it's still 2-3 months before people get their hands on them.
      How much will they cost?
      Another one that's still early to commit to. I know there are services that will add a simple 1/8" aux jack to the faceplate of these radios for $60 and that a half-decent aftermarket head unit costs about $130. I want to be somewhere between the two.
      • bradnic
        • Jul 2012
        • 3554
        #48
        I'd say walk before you run, but know where you're going. Extending the design to support other radios significantly increases complexity for you, and delays for us.
        So by all means confirm the design diffs between the similar alpines, but please don't take too long :-) if you can leverage similarities and build some modularity into your design to accommodate them that's great. Hopefully you can adapt the design over time - but not all up front though and not make us all wait too long..
        Why don't we get a survey going on the site? Find out which OEM radios folks are willing to buy a retrofit BT solution for.
        HOWTOs:
        OEM Keys
        MTech1 docs
        88 ix Lach/Card
        91 ic Calypso 3.1
        86 Cosmo 2.7
        OEM+ or bust!
        • Todd Black 88
          • Oct 2007
          • 3449
          #49
          Yes
          Yes, I will be wanting to put it into a cm5907/5905 myself. That's what my m3 came stock with.
          Originally posted by codyep3
          I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
          2001 silver/Blk 325 cabby. SOLD
          2002 325xit Sil/blk. SOLD
          2010 F650gs twin
          • bmwman91
            • Oct 2004
            • 3134
            #50
            Could you have 2 flex receptacles on the mainboard, one for each radio? That way users would just plug the flex into the appropriate one, and maybe you could put some logic on there to detect which receptacle is in use so that the MCU would know which set of code to run with.
            Transaction Feedback: LINK
            • tuckerware
              • Mar 2017
              • 87
              #51
              I'd lean towards selling just the 5908 solution intitially since that has been your test bed.
              As is common with new product launches, I'm sure you'll learn a few things and you can incorporate any improvements into subsequent variations and manufacturing runs.
              Your expected price range certainly seems like a great value so I'd imagine you'll have plenty of takers.
              1989 BMW 325is Coupe - Alpine White
              • reelizmpro
                • 9559
                #52
                Brilliant. Is this to be used with the premium sound amp or does it have an onboard amp?
                88 M3 - LACHSSILBER
                89 M3 - ALPINEWEISS II
                • bradnic
                  • Jul 2012
                  • 3554
                  #53
                  Doesn't affect the amp stage of your head unit at all actually.. so whatever you run amp wise is fine
                  HOWTOs:
                  OEM Keys
                  MTech1 docs
                  88 ix Lach/Card
                  91 ic Calypso 3.1
                  86 Cosmo 2.7
                  OEM+ or bust!
                  • reelizmpro
                    • 9559
                    #54
                    What I was getting at was that some cars have premium sound and some don't. Some cars have had their premium sound amps bypassed. So if this unit is to be used with the factory premium sound amp, then there's more work to be done on those cars. Cars that don't have premium sound would then need to run an amp, correct?
                    88 M3 - LACHSSILBER
                    • bradnic
                      • Jul 2012
                      • 3554
                      #55
                      He's only modifying the input stage of the head unit to add BT music and phone. So no affect on the amp part at all as currebtly implemented
                      It WILL come in to play if/when you add line level outputs to the OEM unit at some point. The OEM premium amp has speaker level inputs which just aren't as clean. The design is basically obsolete. While it's true you can use speaker level inputs with some aftermarket amps, it defeats the purpose of adding an amp in the first place. If/when line outs get added you can bypass the OEM premium amp and use your favorite after market power and subwoofer amps with the OEM head unit.
                      BTW I haven't seen it mentioned here but there are 2 other retrofit possibilities. they are admittedly less useful than what he's chosen to implement in the prototype, but they are there:
                      - most of the newer BT chips support track and caller info display. You could retrofit the OEM LCD panel at some point as well to take advantage of this to display not only track info but caller info too. You can certainly make a strong argument to just use the phone display for these functions instead. After all you're gonna have a separate nav display anyway..
                      - the 5908 and several other OEM head units have a CD changer connector. What he's done here is much better though, since the same existing button controls work across all input sources including the added BT music and phone inputs.
                      I do think the control assignments used in the demo vid could be improved slightly, but it's quite usable as prototyped
                      HOWTOs:
                      OEM Keys
                      MTech1 docs
                      88 ix Lach/Card
                      91 ic Calypso 3.1
                      86 Cosmo 2.7
                      OEM+ or bust!
                      • jaysterling
                        • Sep 2016
                        • 59
                        #56
                        Maybe, but probably not. They want to be in the same place and if I put them one behind the other it might cause rubbing/strain on the flex for whichever receptacle is in back (since that flex has to come up over the first receptacle then bend downwards towards the second). Good point though, I should verify for certain. The audio output and volume knob harnesses are also slightly different between the two, so I'll need to do have both connectors for those, but they're just little wiring harnesses that are easier to reposition.
                        As far as detecting which is being used, there are a few pins that are driven high always on the flex for 5908 that aren't for 5907, so auto-detection should be possible. After comparing the flex pinouts across both radios, I don't see any HW reason the same receptacle couldn't be used for both, there's just more possibility of installation error.
                        The CSR BT chip I'm using doesn't have a serial interface available for getting things like phone numbers or song titles, but that would be cool. I've done the LCD-hacking on my raspberry pi-based 5908 project with the intent of doing this kind of stuff, and the LCD portion of that project could be brought into this. At that point, it quits being plug-n-play though.
                        Let me know what you'd do different with the buttons. There are some assignments that are forced, like input switching has to be on the volume button push since it's the only event I can get no matter what input is selected
                        So here's my plan: I'm going to rev the board fixing all the issues til now I've found. I am going to switch a larger PIC microcontroller since I'm out of program space on the model I've been using (with a few fixes to still add) and I need more IO if I want to support the 5907. There is a little work in switching to a different MCU, but I need more program storage space anyway, regardless of 5907 support. I'm going to hook all the IO up to the new MCU for 5907 support, but I can work on that as I get to it without holding up the plan for 5908.
                        • djjerme
                          • 5082
                          #57
                          just keep us updated. I've gathered a few slider radios, and if you need some beta testing I can help with that..
                          2016 Ford Flex
                          • bradnic
                            • Jul 2012
                            • 3554
                            #58
                            same here. 9 sitting in a box right now. I will keep 3 and sell the rest upgraded for cost, probably next year.
                            HOWTOs:
                            OEM Keys
                            MTech1 docs
                            88 ix Lach/Card
                            91 ic Calypso 3.1
                            86 Cosmo 2.7
                            OEM+ or bust!
                            • jaysterling
                              • Sep 2016
                              • 59
                              #59
                              So I got back rev 3 of the board on Monday, assembled on Tuesday evening, worked on new MCU bring-up Wednesday, and things are moving along well over here. I left out a few parts on my digikey order that should get here tomorrow so that I should hopefully have a full working board with noise-free audio appropriately gained and with no jumper wires working by Saturday, then install it in my E30 on Sunday :)
                              • Chrisbike
                                • Mar 2015
                                • 688
                                #60
                                Great news! I am installing my factory radio tonight in anticipation of this. Thanks
                                Build Thread
                                https://www.r3vlimited.com/board/sho...d.php?t=419655
                                Parts Thread
                                https://www.r3vlimited.com/board/sho...d.php?t=408302
