Blaupunkt Liverpool 110 Headunit
  • Eurospec
    • 2613
    Came across a blaunpunkt deck that not only looks great but has all the bells and whistles with what appears to be red/ amber illumination. Oddly enough I can't seem to find too much information about it. I've even navigated through Blaupunkt's website to no avail. Could it be an international unit?
    I'm really considering picking this up for my e30. Curious if anyone has this particular unit or something similar. Will I have buyers remorse?
    s-l500 by dtmpwr, on Flickr
    s-l400 by dtmpwr, on Flickr
    Here's an unboxing vid,
  • IceWhite
    • Jan 2015
    • 945
    1990 325i
    2004 330i Individual 6-speed
    • Eurospec
      • 2613
      Thanks for that. Please do share how you embedded. Couldn't figure it out for the life of me.
      • IceWhite
        • Jan 2015
        • 945
        Glad to help out. If you quote my post, in the editor, you will see all that is required from your link address is the alphanumerics after the "equals to" sign. This code should be within the YouTube tags.
        Try it out!
        1990 325i
        • bmwman91
          • Oct 2004
          • 3128
          That is a nice, modest-looking head unit. You can also look at some of the Continental ones if you are after an OEM look.
          The other thing that you can do, and I highly recommend it, is to crack open the faceplate and swap out all of the little surface mount LEDs for 605nm orange ones. It is fairly simple soldering, and it makes the unit blend in seamlessly at night. I have done it on 3 different head units (and for a few other forum members) and it was well worth the effort. Getting the brightness right is a little tricky sometimes, but I can recommend some parts that have been very good matches.
          Transaction Feedback: LINK
          • DaniTD
            • Sep 2017
            • 44
            Hi! I can't see IceWhite post. Did you finally bought It? I'm also looking for It on my E30 but there is not much info or photos of It installed!
            Thanks!
            • robrez
              • Jul 2008
              • 3376
              Although it's NLA new, the Blaupunk 400BT can still be found. I love mine, especially with the steering wheel controls
              It would be near perfect with the hack described below and changing frI'm negative to positive display like the obc with polarizing film.
              January 2012 COTM
              • DaniTD
                • Sep 2017
                • 44
                The photos are down! :(
                Finally I bought a Liverpool unit. I'm a little bit concerned because it doesn't appear on the Blaupunkt website and the new units have the specs not too much described on the user manual, so I'm not sure about the quality of these units. On the box it says designed and engineered in Germany, although former Blaupunkt headquarters in Hildesheim close due to bankruptcy in 2016 (maybe these are the last units ever engineered in Germany although made in China).
                I will post some photos when installed. I will pair it with some Blaupunkt Velocity series speakers on my E30, since they're old, high quality and low wattage rated, perfect for running with a head without external amp (unit gives 40Wx4 max, about 20W RMS, and the speakers are about 50W RMS).
                • robrez
                  • Jul 2008
                  • 3376
                  Photobucket links fixed thanks to this hack
                  Originally posted by clarkson
                  So to all the photobucket users who have created build threads, if you put "~original" after the .jpg in your links your pics will work.
                  January 2012 COTM
                  • sonomabimmers
                    • Dec 2015
                    • 802
                    Came a little late but i had that head unit. Volume was crap and bluetooth were crap, hated it. Hopefully it serves you better.
                    i love bmws
                    • DaniTD
                      • Sep 2017
                      • 44
                      Don't tell me that this specific model? Was it that bad?
                      • sonomabimmers
                        • Dec 2015
                        • 802
                        Wasn't that terrible but it was noticeable mainly I had problems with Bluetooth and connecting. Sound quality was bleh. But I also didn't have the best speakers. You'll be fine. But I wouldn't buy again.
                        i love bmws
