antenna stopped working. why?
  • cheffy30
    • Sep 2016
    • 1159
    as usual the stereo works perfectly and the antenna went up and down when you turned it on and off. now it doesn't go up when turned on.
    all i have done is changed out the fuse with a new one, #28/30amp fuse.
    still nothing.
    anyone have a suggestion as to my next step for troubleshooting?
    thanks guys
    '90 325i sedan daily driven
    '85 325e coupe also a daily
  • jeffnhiscars
    • Jun 2011
    • 6010
    Most common problem is a broken mast. Second is a busted tab that sits between the 2 large white plastic gears, third is usually the and then there's a stripped helical drive gear. All this assumes your antenna is getting power
    Alice the Time Capsule
    • cheffy30
      • Sep 2016
      • 1159
      after replacing the fuse i noticed the lighter didn't work either... both are connected at #28
      i re- replaced the fuse and then got power to the lighter again and somehow, while not noticing, the antenna went up and is now stuck in the up position.
      mast is not broken.
      seems there is power since it went up.
      jeff, do i need to take the motor apart?
      • Zeemz
        • 485
        Time for a Z3/318ti antenna upgrade
        Here is it is on my current car.
        On my old car I had also had the 318ti base, but I used an antenna from an S2000, I liked the appearance better since it was a shorty, but the stock Z3/318ti came with does have better reception.
        1989 325is Lachssilber - Sold
        1990 325is Sterlingsilber - Current Project
        September 2018 Car of the Month: Zeemz
        Youtube Track & Autocross Videos
        • cheffy30
          • Sep 2016
          • 1159
          hmm, i'll have to look into that... seems smart at this point.
          thanks for the advice...
          • Zeemz
            • 485
            No problem. This guy has sold a bunch on the board and posted that he had one the other day.
            • jeffnhiscars
              • Jun 2011
              • 6010
              mast is not broken.
              Unplug the antenna and run a positive jumper from your battery. Contacting both antenna wires at once should make it go down and one wire makes it go up (or vice versa...you'll figure that out). If it works your problem is body wiring. If it doesn't go up and down then you will have to take it apart.
              It's possible for a bad mast to go up and not down but youdnhear the motor running. Otherwise my money is on the antenna control board. I'm wrestling with one now and none of my spare boards work
