Speaker suggestions
  • Brew
    • 3060
    Originally posted by bwanac
    Your right. So the speaker is mounted to the kickpanel?
    This may just be me, but wouldn't it sound better (bass wise) if it was mounted to something a little more secure? The kickpanel is pretty sturdy, but not nearly as much as the sheet metal.
    I don't think so.... My Kappa 6.5's are bolted right to the sheet metal. They are VERY tight, but it works and they sound awesome. I also had to cut up my kick panel for the speaker grille, and I had to make a spacer for the hood release lever.
    '91 318is
    • clavinZERO
      Hella sick E30
      • Mar 2004
      • 2027
      no no no ..... not mounted JUST to the plastic kick panel. i cut a hole in the panel so the magnet could fit inside, then i drilled holes in the panel so the NEW mounting ring (gold-colored metal ring) could be fastend to the 4 stock speaker screw holes. then the speaker was mounted onto the metal ring. there you have it. sounds damn good if you ask me.
      "BMW Style 32 Poster-Child"
      HTTP://WWW.CLAVINZERO.COM/e30-5-lug
      **(My Guide to E36 M3/Z3 1.9L 5-lug Swap)
