analog clock install
  • Mike30e
    • Jan 2009
    • 410
    #46
    I find that the analog clock loses a couple of minutes every couple of weeks. But it looks so much better in the dash than my 6 button OBC...
    • NC325iC
      • Mar 2004
      • 6565
      #47
      i went to wire mine up yesterday and couldnt find a wiring harness where the OBC was, where might i find this wiring harness?
      • NeoMishMoo
        • Jul 2009
        • 448
        #48
        Wait did you not have an obc? Or was it not connected? Surely the wiring harness must be down in there somewhere. Maybe it fell down behind all of the heater controls. The hole is small so you might not be able to get your hand in there to fish it out. It would be easier if you removed your stereo and/or that plastic panel that on the right side of your console that runs all the way back to your glove box.
        I know that whenever I am able to squeeze my hand through the OBC hole I always regret the decision when it is time to remove my hand.
        If you really don't have a harness you could just run new wires to your clock, that is what I did before finding this thread (I just lazily wired it up hot without illumination).
        West German BMWs, they just don't make the same as they did before the wall fell.
        ^Case in point: Auto-Repair Technology. Everytime my car isn't starting or acting up I let it sit, sometimes for an hour, sometimes for days. But it eventually fixes itself.
        • bimmerboy08
          • Apr 2009
          • 353
          #49
          this is a great writeup. Works perfectly if followed, make sure to undo the battery connections, and be careful not to lose the screws.
          • SimplyDope
            • 1335
            #50
            Apologies for the bump, but I'll be following this writeup tomorrow :) Using bullet connectors since that's all I have around. I've had the clock in the car for a while just never bothered to wire it in haha.
            Edit: Just installed it. peerless' additions made it very easy. Worked the first time I reconnected the battery. Thanks!
            I'll take pics soon when I make more progress with the interior :)
            • 5ickride
              • 2922
              #51
              Followed these instructions and it works flawlessly! Thanks for the simple step by step write up!!
              • spiDmang
                • 3941
                #52
                is there any other way of wiring this up besides using a power mirror connection, or the stock plug? Im hoping to find like single connectors for each connection (if that makes any sense)
                91' 318iS - S54/6MT Swapped
                08' E90 M3 6MT - Daily
                Originally posted by IronJoe
                Originally posted by 2mAn
                • bubbajan21
                  • 1962
                  #53
                  Why? Just use the mirror plug, it fits right in and makes it really easy. Don't make more work for yourself than you need to.
                  • travis325
                    • Jun 2011
                    • 55
                    #54
                    thanks for the great info guys! I'm going to try it tomorrow and post pics!
                    • bzboardz
                      • 1096
                      #55
                      Originally posted by 5ickride
                      followed these instructions and it works flawlessly! Thanks for the simple step by step write up!!
                      this +1
                      • FreedS4
                        • 752
                        #56
                        I'm trying to re-install my multi-function clock, but remember where each original wire goes. Any have this info? Thanks
                        Chris
                        • FreedS4
                          • 752
                          #57
                          Just need someone to snap a quick picture of the harness. Anyone, a little help?
                          Chris
                          • kumulonimbus
                            • May 2012
                            • 178
                            #58
                            Just installed my analogue clock following OP's instructions, clock is running great. However, now the SRS light on the over head display continuously blinks. Anyone have this happen to them?
                            1990 BMW 325i Coupe
                            • mcskibadee1
                              • Feb 2012
                              • 1379
                              #59
                              Could one of these be used instead of butt connectors? Just seems if I ever wanted to go back to original it would be much easier.
                              Is this the correct way to get to the clock so I can install it?
                              TRANSACTION FEEDBACK HERE
                              FOR SALE ITEMS HERE
                              • blackhawkimpact
                                • 2415
                                #60
                                You can use whatever you want, even electric tape. ;)
                                It just won't be a clean, professional look, and can be explosive to your car.
