analog clock install
Could one of these be used instead of butt connectors? Just seems if I ever wanted to go back to original it would be much easier.
Is this the correct way to get to the clock so I can install it?
http://home.comcast.net/~cdeegan9/da...shboard_4.html
When I did it, I didn't remove my radio. I removed the right side panel where the glove box is, but I think you don't even need to do that. You just need to pry off the old clock's face, then push down the two plastic things (see pic) and slide the clock out.
1990 BMW 325i CoupeComment
Ok, I just did this in my 91 318is and it looks great. Clock works great. problem is my tach is now not working!!! I followed the instructions to the letter. I had read that other people had this issue in the past. I have searched and I can't find the fix???
Help!sigpicComment
Tach signal can be verified by probing the blue connector's black wire, pin 7 while the engine is running. Measure AC volts with a digital multi-meter. It should read 1.5-6V AC.
If tach signal is verified (from the ECM) then the problem most likely lies with dead SI board batteries. If batteries have been recently replaced, I would assume bad/cracked solder joints on the cluster main board, then bad tach motor assembly.Owner - Bavarian Restoration
BMW and European Electronics Repair and Restoration
www.BavRest.com
My Feedback Thread
Our Facebook!
Follow our Instagram!
You probably made a short when installing the clock and your cluster board is toast. Exactly what happen to mine. IDK how it happen but after I installed the removed the OBC my tach stopped working and it was the board that was burntComment
First I have heard of this. Did this in both my cars with no adverse effects. Just don't short anything out and make sure you are connecting everything correctly. Check twice, splice once.Comment
So do you just cut 4 wires from the green connector that goes in the 6 button OBC and leave the rest of the wires connected to the green connector for ease of re installing the 6 button? Also is there a adapter from 6 button female to a female analog connection? I hate splicing stock wires, like really hate it
1992 e34 Touring- S50 Swap
1992 325i-S50 Swap (SOLD)
1991 Brilliantrot Convertible 80k Miles (SOLD)
1992 318i Convertible Project-Finished (SOLD)Comment
