I searched everywhere on the forum and could'nt find a write up on this ( i could be wrong) anywho here it is:
This is for the multi-function clock harness.
Whats needed:
Female power mirror plug
4 butt connectors
wire cutters
wire crimper
Once you remove the mf clock you will see a harness which has about 12 wires, you only need 4. The analog clock has a # above each pin
30-power
31-ground
58k-illumination power
31g-illumination ground
So what you need to do is grab the mf clock harness and cut these wires:
red/white-power
brown-ground
gray/red-illumination power
brown/white-illumination ground
the rest is simple, just connect the wires and bam!
Sorry if i left anything out, this is my first write up, hope this helps some of yall.
Whats needed:
4 butt connectors
wire cutters
wire crimper
30-power
31-ground
red/white-power
brown-ground
