E30 M3 DME Failure Common?
  • IHeartE30s
    • Jun 2007
    • 129
    So I figured my DME (ECU) wasnt taking the coil drive/final stage fully to ground. It would go to 12v and tickle it down to 7-8V so there was no spark output.
    I was looking threw the Technical Service Bulletins for the car and nothing came up, I did although find one that said: "When a DME's final stage fails it might overheat the coil and a replacement is required." That lead me to believe that it might be common if they're stating it. Knowing that will better justify my spending on the DME unit.
    Anyone know if its a common failure?
  • reelizmpro
    • 9558
    Somewhat. I'd say more common than a 325. Mainly transistors that overheat and fry up on the ICV circuit and the others just plain fry up or have water damage. Try another DME to troubleshoot.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • IHeartE30s
      • Jun 2007
      • 129
      Well I tried it and it works, I actually sent mine out to get fixed and it worked but failed again after about a month. They said they just fixed some loose ground soulders.
      Im hoping its just the DME and not something bringing it down, I check all electrical components and all the ones I could get to are in spec.
