Hotwiring an e30
  • James Crivellone
    Head Janitor
    • 6303
    If this is for illicit purposes I'm going to be pissed....
    Anyway, you are all over complicating this. Just take the bottom steering column cover off, remove the red ignition switch (clipped in place) and start the fucker with a screwdriver. You would still need to destroy the lock cylinder to turn the wheel though (wheel lock)
    • h0lmes
      I just would like to be able to hot wire a car if I need to. I would never steal a car just for the hell of it. There may be some time down the road, such as a zombie invasion, where I may need this skill to save my life.
      • Nicademus
        • 2912
        I agree. You'd hate to be stuck sitting in the car while the zombies kept creeping closer looking like this :puppy:
        Well, posterity, you will never know what it cost us to preserve your freedom. I only hope that you will make a good use of it. If you do not, I shall repent in heaven that I ever took half the pains to preserve it.
        ~ John Adams ~
        • evil_twin
          • Nov 2007
          • 2965
          Pssh why play with wires? Just pull the electrical connector on the back of the lock cylinder, use a flat head to turn that electrical piece. All the lights and everything will work, as far as the steering wheel, 22mm and a good yank and it should pop off eventually. How do I know this? I had to do it for my car to pull it into the garage one time because my lock cylinder was messed up and still is.
          Paypal: vdang5@gmail.com
          Delta Auto Care
          2875-C Towerview Road
          Herndon, VA
          703.435.1375
          My Feedback Thread: Evil_Twin
          • AlarmedBread
            • Sep 2006
            • 1510
            Spray starting fluid inside the lock cylinder (the pressure will unlock the wheel), then short the red/green and touch the black wire to start it.
            • jeer
              • Sep 2007
              • 32
              to get the plastic column trim off is not as easy said as the screws are behind the steering wheel and using a pry bar to break it off is a real pain.
              why would you just break everything when its your own vehicle, then you have to find replacement parts or drive around looking like you just stole a car, then when you get pulled over it will be freaking 60mins barbera walters type questions from six officers, lol not really but could very well end up that way,
              if you really really want to know, take your car apart and see how it all works while off the right way and you could see what needs
              to be done the hack or theft way... use a good wiring diagram and figure out the ignition wires, even though it just slips off the back off the ignition lock anyways,
              • evil_twin
                • Nov 2007
                • 2965
                If your car is a super duper race car or you just don't care, you can pop it off.
                Delta Auto Care
                Herndon, VA
                703.435.1375
                • Huff
                  • 2488
                  What if it's a 13 button and the code is on? How do you get the fuel pump going...
                  • SpecM
                    • Oct 2005
                    • 4531
                    Originally posted by NitroRustlerDriver
                    Slide hammer screwed into the lock cylinder. A few good whacks will pull it right out.
                    I like that idea ;)
                    1989 cirrisblau-metallic 325i
                    • e30rcr
                      • 383
                      Work at a shop where a stolen car gets brought in to fix it, then examine. Take notes children!
                      • thereisnoyun
                        • Feb 2007
                        • 2301
                        I would just learn some kung fu, and buy a katana and lots of guns and ammo.
                        • jeer
                          • Sep 2007
                          • 32
                          :evil: hahaha thats the best idear yet! :-D
                          dont forget to study up by watch all the best zombie movies
                            • 34839
                            unplug the battery for 5 minutes. code disappears.
                            not exactly rocket science :p
                            • EN318isPDX
                              • Oct 2007
                              • 4373
                              This thread is funny.. i wonder how many police we have on the forum that are trying to find this guy
                              • Huff
                                • 2488
                                I thought (maybe assumed) that the OBC used the SI board batteries for a power/charge? Have you cleared the code by unplugging the main battery before?
