Trunk rattle.
  • Red88
    • Nov 2008
    • 1159
    Trunk rattle.
    I have the other two carpet-holder-uppers, I was eager. I built the box, and wired it all. It's just two twelves that move every piece of metal in my trunk.
    Next step: Dynamat.
    Have you made a purchase from www.blunttech.com recently?
    sigpic<< wrecked
  • kronus
    • Apr 2008
    • 13025
    so maybe back off the bass a bit?
    cars beep boop
    • DCColegrove
      • 2748
      Dynamat...
      And pad all the works...especially the deck lid torsion springs...
      I don't know shit about sound equipment but I do know rattles.
      • kenika65
        • Aug 2007
        • 1336
        all i had to do is tighten the trunk latch. it is adjustable...
        1986 325es (69k) Garage Queen Buy It Now 10k;1986 325es (track rat) 2.7i How-To & 1.1/1.3Motronic UpGrade
        1991 318is (daily driver) 1991 318is M42 Maintenance How-To;1989 325i (parts car)
        • Mr Watsonsilver
          • 452
          i have the same issue.
          • kenika65
            • Aug 2007
            • 1336
            ^ then adjust the trunk latch hook on the trunk it self, once adjusted the trunk wont just shut by pushing down you have to make it shut, but all of the rattle will go away well at least it did for me and I am pushing 2500W
            • Mr Watsonsilver
              • 452
              Ok..i will try that in the morning.
              • Stevie30
                • Apr 2007
                • 1534
                Check your license plate. I hear a lot of plates rattling while stopped at traffic lights.
                1991 325ic and 1991 318is
                • Mr Watsonsilver
                  • 452
                  I checked. There is about a quarter inch between the plate and trunk. So i dont think that is the problem.
                  And I still cant find the trunk leak problem..its getting worse to.
                  • kenika65
                    • Aug 2007
                    • 1336
                    I found my trunk leak at the trunk mounting welds which hide almost under the weather stripping.
                    I had to re weld and repaint over the welds...
                    I found this leak by poring water and watching for water...
                    • Mr Watsonsilver
                      • 452
                      That sounds pretty extensive for me to do.
                      • StereoInstaller1
                        GAS
                        • 22679
                        Trunk rattles are easy.
                        My roof moves a good 1.5"...try fixing that rattle!
                        Closing SOON!
                        Thanks for 10 years of fun!
                        • Mr Watsonsilver
                          • 452
                          WOW what do you have for a system?
                          • StereoInstaller1
                            GAS
                            • 22679
                            1 12" Exile sub on 600 watts in an ultra high tech box.
                            The port tubes are almost 30" long, to achieve the tuning frequency that gives me bass below 20Hz, yet achieves about 115db with 1 watt, in my car.
                            Closing SOON!
                            • StereoInstaller1
                              GAS
                              • 22679
                              One more showing the top of the port tubes:
                              Keep in mind that this will make better (and more) bass on 1/10th the power.
                              Luke
                              Closing SOON!
