Terminal replacement &allocation
  • gerrycg
    • Feb 2018
    • 14
    Hey y’all, I need help finding terminals. I have never worked out an electrical issue with my e30 so I don’t know how specific I need to be with things. I’m looking for 2 different terminals. One terminal belongs to the C101 pin out and the other one to the DME. Thanks I’m advance and stay safe! Sent from my iPhone using Tapatalk
  • jgilber0
    • Nov 2016
    • 457
    Check TE Connectivity, they may have it. Mouser Electronics is a distributor that also carries a broad line of connectors and pins. Good luck!
    Jon (OO=[][]=OO)
    1992 325ic white, stock with a 5-speed swap
    Palm Beach County
    • gerrycg
      • Feb 2018
      • 14
      Thank you! Sent from my iPhone using Tapatalk
      • McGyver
        • 4637
        Digi-Key is also a good resource.
        I spent hours trying to understand the different search categories on Digi-Key and Mouser. Eventually I went TE Connectivity's website and found a manual for the Junior Timer connectors (under Datasheets & Catalog Pages):
        https://www.te.com/usa-en/product-1-...e=header-match
        I imagine they will have a similar catalog for what you need.
        • Vincenze
          • Apr 2019
          • 1037
          Check the sizes in the descriptions and google the numbers for images.
          Maybe, these:
          #3 in https://www.realoem.com/bmw/enUS/sho...diagId=61_2486
          #2 in https://www.realoem.com/bmw/enUS/sho...diagId=61_1029
