Rear speakers fabric
  • Thunderzol
    • Feb 2017
    • 269
    Does anyone know what the fabric/mesh is called that’s attached to the bottom of the speaker cover? And where to buy it?
    thanks!
  • Vincenze
    • Apr 2019
    • 1029
    Just google "Speaker grill cloth".
    It's usually used to cover speakers from outside.
    It comes in different colors and weights. Probably, light weight is more appropriate for attaching at the bottom, but then dust will pass through it.
    https://www.parts-express.com/cat/sp...oth-fabric/319
    • monty23psk
      • Mar 2008
      • 1289
      speaker grill cloth fabric, grill cloth, speaker cloth, speaker fabric,acoustic fabric, grill fabric, acoustic cloth, grille cloth, speaker mesh, black, brown, white, grey, gray, green, beige, for sale, buy, cheap, sell
      This is great. I was about to rebuild mine and start searching and asking here.
      Alex 88 m5 | 91 318is | 19 Subaru Ascent
      BMW Tool Rentals & Fender Roller
      • Thunderzol
        • Feb 2017
        • 269
        I’m afraid these are too thick. I had Googled for an hour before the OP. I’m looking to match the thin paper-like film under the speaker cover.
        thanks!
        • roguetoaster
          Biggus Tippus
          • 7830
          You may want to consider a mildly open woven fabric to match the original aesthetic if a 1mm open cell foam won't cut it for you.
          • Vincenze
            • Apr 2019
            • 1029
            Try fusing then.
            You’re seeing this message because some of your behavior on the site looked a little odd. To continue on through the site, help us verify that you’re a real person.
            It can be paper-based or woven.
            Usually, you put it on a piece of fabric and use an iron to slightly melt the glue on one side.
            I don't know about its acoustic properties.
