About the e30 convertible.
This is a sticky topic.
  • fuzzysux
    • 247
    #31
    regarding the top not folding correctly - there is a bar which links the motor on the pass. side of the car to the top frame. this bar length is adjustable and makes a big difference in how the top folds.
    i have also found tops that open correctly but do not fold right because of broken bolts. when the top opens, it isn't so important since the top "wants" to lay open.. the weight of the front bow tends to align everything where it belongs.
    check all hinge points (on both sides) of the top frame.
    • fuzzysux
      • 247
      #32
      tension straps - these are only rivited in to the top frame at the rear bow (3 rivets on each side). at all other bows, the straps are attached with very short screws.
      at certain angles of the top open/close motion, you can get to most of these screws.
      if you are DIY, it might be worth this method.
      if you are anywhere near close to needing a new top, i suggest to all of my customers to consider the straps at that time. it is much less extra labor to "add" it to the job.
      • rustneversleeps
        • Aug 2016
        • 132
        #33
        Well 2 years later time to resurrected again...
        Anybody have any news on how to install a electric top or where to buy..
        • N2MYE30
          • Oct 2007
          • 5536
          #34
          are asking how to install an manual to an auto?
          COTM
          • rustneversleeps
            • Aug 2016
            • 132
            #35
            as an auto if it available or just to see what all the parts consist of to make it an auto...
            • bradnic
              • Jul 2012
              • 3550
              #36
              i'm converting my 7/90 build manual top to electric over the next few months. check my vert build thread starting April 2017 for info/pics.
              HOWTOs:
              DB vert plastic bumpers
              OEM Keys
              MTech1 docs
              88 ix Lach/Card
              91 ic Calypso 3.1
              86 Cosmo 2.7
              OEM+ or bust!
              • rustneversleeps
                • Aug 2016
                • 132
                #37
                Looking forward to seeing how you install it....
                So did you start or any link..
                • JWHIII
                  • Jan 2014
                  • 104
                  #38
                  I believe it's part of his vert build thread. check here http://www.r3vlimited.com/board/show...264422&page=29
                  • Dagamus(NM)
                    • 604
                    #39
                    Good info to have. Subscribed.
                    Gun control means using both hands
                    Sex, Drugs, Rock 'n roll. Pick two.
                    • rustneversleeps
                      • Aug 2016
                      • 132
                      #40
                      Hey thanks man started reading it yesterday and I'm only at page 5.
                      24 more pages to go.
                      X2....
                      • Echo30V
                        • Sep 2017
                        • 301
                        #41
                        I would expect more action here in the Vert section, what with Verts gaining some traction in price. Still am amazed that the Oklahoma car went for $21,500 on BaT.
                        • phenryiv1
                          • Jul 2009
                          • 3246
                          #42
                          Ever since photobucket ruined forums the traffic has died.
                          Patrick Henry
                          • Echo30V
                            • Sep 2017
                            • 301
                            #43
                            I know, it's really sad. I hope it picks up here. The e30 vert is such a classic.
                            • berndt
                              • Mar 2016
                              • 104
                              #44
                              I saw that auction. Decided to replace the top on my very. Seems like it’s worth it. I hope at least
                              • Echo30V
                                • Sep 2017
                                • 301
                                #45
                                I’m following that red Vert on BaT now. Should be interesting.
