E30 Vert wet rear floors and jack trunk pocket
  • reelizmpro
    • 9543
    Sounds like you have two leaks. Common one for the jack pocket in the trunk is the antenna grommet, tail lights and trunk gasket. Mind as well check the trunklid adjustment as well. I also had a leak on the passenger rear floor only. My issue was the top seal allowing water to drip onto the seat and pool in the rear footwell. My rear quarter seal isn't great and wasn't touching the glass where it meets the door causing a gap. I conditioned the seal, adjusted the rear quarter glass and door, then installed weather stripping on top of the old vertical seal between the rear and door glass. So far, so good.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • allen_t
      • Feb 2014
      • 552
      So I took off one side of my soft top by unbolting the 3 nuts. Lifted it and found the drain in the top storage area.
      Poured a bottle of water in there and traced the leak coming into my rear seat area. The water was also building up on the floor behind my driver seat.
      Here is a pic of where the water is coming from:
      I'm assuming it is clogged somewhere although most of the water does drain from underneath the car under the driver seat.
      Anyone know how I can unclog the drain or have any other ideas?
      http://www.DeluxeCarStorage.com
      87 325ic - Early ACS Tribute
      90 325i MT2 - R.I.P
      Seller Feedback: http://www.r3vlimited.com/board/showthread.php?t=380908
      • allen_t
        • Feb 2014
        • 552
        I think I found the culprit for the rear seat leak. Like others mentioned its the hole covered by sticker under the soft top mounting bracket. I didnt realize it was there until i poked around with a screw driver. This is definitely why the water is leaking in the picture above.
        90 325i MT2 - R.I.P
        • cWalk3r
          • Jun 2014
          • 178
          I figured out my truck leak. I took off the spoiler to paint the car and I guess the seals were old or fell off and didn't complately seal. The rear passenger side floor was one of the body plugs was loose. And now the drivers side floor somehow got soaking over the winter with a car cover over it so I assume it's anot her body plug.
          • allen_t
            • Feb 2014
            • 552
            Body plug? Are these the black plugs undernear the carpet on the floor of the car
            90 325i MT2 - R.I.P
            • IS300E30
              • Apr 2009
              • 408
              Originally posted by Semblance
              Lots of possibilities:
              -Check the vent gaskets (under the bumper trim with the sidemarker in it on each side) - try hosing this down without even taking anything apart - Water gets through there surprisingly easy.
              - third light seal, including rubber washers on all screws
              - taillight gaskets
              - antenna grommet
              - trunk seal
              - make sure the drains in the tonneau compartment aren't clogged
              Not sure about water on the cabin floor in a vert, other than thru the top. Hose it down?
              I know I am bumping an old thread, sorry :)
              However, where is the vent gasket that is being talked about?
              • cory58
                • 1021
                There are vents in both rear quarters hidden by the sides of the bumper. You can see them from inside the rear side wells.
                Gasket replacement is simple once you remove the bumper. The vent units are just held in place by plastic tabs, and can be removed without tools.
                Cory
                1992 325i Cabrio
                1988 320i Touring
                2000 M5
                1977 530i
                2015 328i - Euro Delivery/Performance Center Delivery
                BMWCCA
                E30CCA
                • JerVic
                  • Jul 2013
                  • 25
                  I had the same issue you described a while back, replaced tonneau cover seal and that fixed it.
                  JM
                  • TimeMachinE30
                    • Jun 2014
                    • 3749
                    I think his car would have sunk by now...
                    ACS S3 Build / Dinan 5 E34
                    • cWalk3r
                      • Jun 2014
                      • 178
                      lol still haven't found the rear floor leak. To me it seems like its from evaporating water... cause I've had my car cover on the car about 2 weeks ago for a week or two and noticed that the rear floor was wet. Explains why i can't see where the leak is and next year ill have to take the carpets out and seal up the body plugs in the rear floor. Cars put away for the winter now
