Convertible rear window
  • 87cabrio89is
    • 38
    Originally posted by McGyver
    I probably will, but I'm not sure yet. I ran out of thread and patience (and bent 2 needles and broke the supplied needle), so I'm going to get back to working on it today and hopefully get close to finishing. I sorta wish it looked nicer, but I'm selling the car and it's only getting a window so I can say that the top doesn't leak. I guess I'll take some pictures today to show my process.
    Why not pull the top off of the car to make things easier on yourself? There are only 4, maybe 6 bouts to deal with.
    • McGyver
      • 4554
      Because I'd rather take 2 hours working around something than spend 5 minutes removing the part to make the job simple. But seriously, the car is parked in a garage with no doors or lights and is right off an alley. So I would be too worried that someone would come fuck with the car when they see the top off for however long it tool to sew in the window.
      • fporro
        • 1859
        easier to retrofit zipper type to a 87 and if so, only oem or can it be mcGivered ?
        • MSGGrunt
          • Aug 2016
          • 198
          Is the rubber trim piece part of the window or is it separate? The part that the cloth of the top tucks in under. My top is fine but, the rubber trim piece is all cracked and I have a small hole in the window itself.
          1986 E30 325E
          1989 E30 325iX
          2003 E54 X5.
          1993 Mercedes W124 300E
          1995 Mercedes W124 E320.
          2009 VW Touareg
          2007 Porsche Cayman S
          • Das Delfin
            • Sep 2014
            • 2293
            the trim piece you're asking about is separate
            • MSGGrunt
              • Aug 2016
              • 198
              So the trim piece needs to be glued to the window and then the top glued under it? That sounds like lots of fun. Real OEM doesn't show the trim piece so is it included with the window, either if purchased from a dealer or aftermarket? Just looks sloppy to me without the fabric of the top neatly tucked into the trim piece as originally designed.
              1986 E30 325E
              1989 E30 325iX
              2003 E54 X5.
              2009 VW Touareg
              • Das Delfin
                • Sep 2014
                • 2293
                No if you look at the picture you posted you can see it's glued to the top after. The emiata window doesn't come with it. However you can probably find some non-oem way to make one at the hardware store
                • MSGGrunt
                  • Aug 2016
                  • 198
                  So, if it is glued to the original top, which mine is, where would I buy that channel? It's not shown on real OEM. And to be perfectly honest, the top, IMHO, would not be installed properly without this. Maybe this is already glued on an original factory window? Anyone on here know if that is the case. Seems that if this piece were easily available the aftermarket window suppliers would include it with their windows or at least offer it as an option.
                  1986 E30 325E
                  1989 E30 325iX
                  2003 E54 X5.
                  2009 VW Touareg
                  • reelizmpro
                    • 9494
                    It's flimsy and has a channel where it clips onto the top fabric outlining the window. I didn't reinstall mine when I installed my new window. Needs an adhesive all round to stay put and I figured it might make more of a mess than anything.
                    88 M3 - LACHSSILBER/SCHWARZE
                    • Das Delfin
                      • Sep 2014
                      • 2293
                      ^ yeah it's like a C-channel. There's a slot going down it where it slips over the perimeter of the fabric.
                      I believe the top would have come with it installed. I couldn't find a separate part number for it. Realoem is wrong sometimes but it makes more sense that something as insignificant as that would just be included with the top, especially considering that the top already has lots of other parts which could be separated in the same manner as this piece
                      I didn't reuse mine because it was split etc and I don't really miss it. I'm not taking my car to a concours any time soon. You might have to get creative with a replacement.
                      • bmwtool
                        • Sep 2016
                        • 72
                        Am I understanding this correctly: A zip in window costs MORE than a new top?
                        • Das Delfin
                          • Sep 2014
                          • 2293
                          ^ no get the emiata one. Google it
